Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on 2002 wrx problem at 3000 rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Thanks for your help. Tomorrow I'm going to put the stock intake in and see if that's the problem....
    Registered User cknight2480's Avatar
    Dec 2010
    Grafton, WV
  2. #17
    Apr 2007
    8000' up in Colorado
    Sounds to me like a MAF / airflow issue.
    You may also need to clean your MAF.
    Scott
  3. #18
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    If the car was running fine for a couple of days and then just started acting up...my gut tells me a hose or something popped off/came loose. That may explain why it's only jerking under load when boost starts to build.
    But I've had people tell me that I needed an updated map for just adding a drop-in filter (doubtful but who knows) so maybe your stock tune just doesn't handle the CAI airflow changes. I suspect if you put the stock airbox back on your car will be fine again.
    Steve // 2008 Lexus IS-F // 2011 WRX hatchback (SOLD)
  4. #19
    Dec 2010
    Grafton, WV
    On my way to work Friday it just magically started running fine for about 12 miles, then it started doing it again. So on Saturday I put the stock air box back in and went for a drive and everything was fine. The next day it started doing it again but its not as intense as it was with the CAI. Sometimes it will run perfectly fine now and sometimes it wont.
  5. #20
    Apr 2007
    Have you cleaned your MAF? This is typical dirty MAF behavior.
    Scott
  6. #21
    Dec 2010
    Grafton, WV
    No I haven't done that yet. But when I was putting the stock stuff back in I looked at it and it didn't look dirty. What do I use to clean it with?
  7. #22
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by cknight2480 View Post
    CRC MAF cleaner.
    Unless you have microscopes for eyes, you can't make that judgement.
    Facebook me here
  8. #23
    Dec 2010
    Grafton, WV
    I cleaned the MAF and it's still doing it. Although now it's doing it at 3400 instead of 3000. I'm probably just going to take it to the local subaru dealer and have them look at it Friday on my day off. Do you guys have any other ideas until then?
  9. #24
    zax
    zax is offline
    Nov 2008
    If it's just a jerking/hesitation at 3400 RPM, this sounds like the infamous Subaru grounding problem. Some EJ205 owners found that grounding the Battery terminal to the intake manifold to the frame helped to resolve this issue...
    http://www.scoobymods.com/diy-grounding-mod-t3569.html
    Facebook me here
