Results 1 to 14 of 14
This is a discussion on Should I be worried about this BOV sound? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; http://www.youtube.com/watch?v=afGpvRzo0NE When I go WOT, the sound is the perfect "PSSSHH sounds that you commonly hear everywhere. When I'm in ...
    Oct 2010
    When I'm in low boost, or I'm driving slow and build up the boost to let it off, it gives a weird sound thats almost like a compressor surge but then instantly turns into a PSSSHHH sound as you can hear in the video.
    Is this normal or is my turbo in danger of failing later in time prematurely? I've been told it's just the wastegate and it's fine.
    My mods are:
    External wastegate
    Tial BOV
    850CC injectors
    Stock VF39
    Walboro fuel pump
    FMIC
    Upgraded radiator
    Greddy turboback
    Perrin intake
    Manual boost controller
    On a tune for 20PSI but I'm running 15PSI until I learn how to drive it better till I turn up the boost.
    I know i have alot of stuff that's ready for a big turbo just don't have the money yet
    Registered User wo^tron's Avatar
    Jun 2010
    Naples, FL
    As far as I know its perfectly fine dude
    Just as long as you got the right spring ratings for your blow off valve
    Put aside the everyday world and come with us
    Into the realm of imagination
    The middle ground between light and shadow
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    2.5L or 2.0L?
    There's no way you'll be getting compressor surge at partial throttle on a 15 PSI tune. I would, however, check the spring rate for you BOV as detailed below. Any particular reason you're running an aftermarket BOV?
    Facebook me here
    Apr 2007
    8000' up in Colorado
    2.5L or 2.0L?
    See below..... I guess he doesn't realize "perfect sounds" may cause perfect problems..... He likes to use an MBC too, which of course is highly recommended on these cars.
    Quote Originally Posted by kayma View Post
    Scott
    zax
    zax is offline
    Nov 2008
    Yeah, I never quite understood the fascination with manual boost controllers. The EBCS gives much better adaptability and control than manual spring-and-ball boost controllers... it's like a step backwards in automotive evolution...
    Facebook me here
    Registered User KnightFury's Avatar
    Sep 2010
    salem, oregon
    +1!! I hear dsm guys talk bout em all the time stating as if they are cooler than **** that they "controll" the amt of boost " i can go as high as i want"
    Think they havent figured it out yet so i let em be, to some ignorance is bliss lol
    On a car that's been custom tuned (with his mod list, I'm guessing he has been), there is absolutely nothing wrong with running an MBC. It's just a different path to the same goal.
    There are trade-offs.
    MBC offers superior boost response to the BCS, at the cost of not allowing the ECU to regulate boost. BCS allows the ECU to regulate boost, at the cost of response.
    The solution: install both in a "hybrid" setup.
    Moderator Donkey's Avatar
    Da boonies
    Nothing wrong with an MBC if your tuned for it. They both have their pros and cons. The EBCS is also a huge PITA to tune and no tuner will ever get one 100% dialed in because of the compensation tables.A good MBC will rarely fail or overboost/spike widly like a EBCS and are easy to adjust. If I over boost in the winter 1-2 psi I just turn it down. With and EBCS unless you know what your doing and have a Tactrix cable your paying for a retune.
    2002 FORESTER S
    1998 FORESTER S
    Apr 2007
    I didn't see anything listed about what tune (if any) he's running, so I didn't assume there's a custom tune.
    Scott
    zax
    zax is offline
    Nov 2008
    I'm not familiar with this setup... Is this similar to utilizing a 3-port solenoid? I know with the 3-port EBCS you can cut your WGDC in half and get better response. How do you run a manual boost controller with an electronic solenoid in the same setup?
    Ah, that's true... I'm just not wild about removing the ECU's ability to control boost. Allowing the ECU to pull boost and engage limp mode when detecting conditions such as knock [to me] is an imperative. Although, if you are really careful, I can see the draw to an MBC...
    Facebook me here
    new hybrid mbc/ebc method of boost control - NASIOC
    Oct 2010
    "On a tune for 20PSI but I'm running 15PSI until I learn how to drive it better till I turn up the boost."
    So yes I am tuned but for 20PSI.
    So the sound is fine then? It doesn't sound like the intense compression surge sounds that I hear about on youtube. It's some odd sound. It's like it has the awesome surge sound for like 50 millaseconds and then goes to a PSSSHHH sound. I guess its just the external wastegate?
    and the reason for the aftermarket BOV is because I'm ready to swap in a bigger turbo as you can see in my mod list lol.
    zax
    zax is offline
    Nov 2008
    You are aware of the problems associated with running a BOV, correct? The stock BPV will hold reliably over 20PSI, but your bottom end won't. I think you need to do some research before your car ends up on a flatbed.
    Facebook me here
    Oct 2010
    Yes I'm aware an aftermarket BOV isn't all that perfect. And I'm not going over 20 PSI so my bottom end will be fine...
