compression test results... please tell me how it looks...
Results 1 to 9 of 9
This is a discussion on compression test results... please tell me how it looks... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I did a dry compression test today to diagnosis my misfire issue here they are... and please if anyone knows ...
    Feb 2010
    SL,UT
    I did a dry compression test today to diagnosis my misfire issue here they are... and please if anyone knows the specs please tell me how they compair...
    06 subaru WRX EJ255
    Cylinder #1. 90-120
    cylinder #2. 60-120
    cylinder #3. 80-120
    cylinder #4. 80-110
    I've replaced the spark plug in the 4cy and switched around the coil packs plus the dealer checked the injector too and it all checks out.... any ideas? Next I'm going to check the fuel filter/pump and sock and also going to reground the ground wire on that cylinder's coil pack... if that doesn't clear it up I give up...
    Hawk-Eye Alliance #801
    Feb 2010
    SL,UT
    Bump.... anyone?
    The numbers seem too uniformly low to be true. You started all this looking for a solution to a misfire in cyl4, yet now all four cyls are relatively low. Did you crank the motor long enough to get an accurate result?
    Feb 2010
    SL,UT
    I thought I did, but the engine was cold too... so I'm sure that would make a difference as well... now that I've been reading about it online... had the engine been warm would the numbers be higher or lower?
    In theory I'd expect the numbers to be higher, as one would think things would seal better as metals expand under heat.
    I don't know if you disconnected the fuel pump power supply, or even if the chance presence of fuel in a cyl would affect the numbers much, but the engine temperature would make a difference for sure IMO.
    In any case from what you have said in this and the other post I can't tell whether the compression is your problem with the CEL, but I don't think so, for what that's worth.
    Feb 2010
    SL,UT
    I couldn't find the relay for it, so I took out the back seat and disconnected the clip on it... the main reason I did the test was to see if it was an internal engine issue and since the numbers are within 10% of each other and it was a cold start it should be fine.... if it were a dead cylinder there would've been a big difference in the numbers... so I'm thinking it has to be the ground wire on the 4th cylinder... it is a small misfire and that would make sense for the situation, cause if it would've been one of the other issues that I checked there would be a more noticable cause....
    I tend to agree with the line of thinking. Regrettably ground faults and misfire CELs seem to be hard to trace sometimes.
    Aug 2009
    Canada/Ethiopia/Madagascar
    Elevation affects your results; SLC...4300 ft... you'll never see sea level numbers. 120 psi at your altitude is not bad.
    It is odd that that 4th cylinder is lower however. Perhaps try doing that one again and get a leak down test. There are compensation factors for various altitudes, idealized, so it's best to go by your local atmospheric pressure if you want a rough idea (not normalized data from the weather channel, you have to find "station pressure").
    ...Rob.
    Feb 2010
    SL,UT
    Sd- missfires are a major PITA it pinpoint, but I've had pretty easy fixes in the past.... also subaru's are very finicky and the slightest difference somewhere will cause a symptom of some kind...
    Mud- thanks for the info, that makes sense with the elevation would cause lower readings and numbers... I'll have to check the local atmosphere pressure here...
    Thanks guys your are awesome...
