No oil on dipstick but no oil light?
Results 1 to 14 of 14
This is a discussion on No oil on dipstick but no oil light? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just changed my oil, and found that there was no oil on my dipstick. My oil light never came ...
    Registered User elitex109's Avatar
    Jul 2010
    Rhode Island
    I just changed my oil, and found that there was no oil on my dipstick. My oil light never came on and my oil was changed 5000 miles on synthetic. The only light that has ever come on was the check engine, which was for an evap leak which will be smoke tested next week. Is this the problem? Im shocked right now that i just drove with almost no oil.
    AWD TURBO FTW!
    Aug 2009
    Canada/Ethiopia/Madagascar
    The oil indicator light will come on when it's much, much too late to do anything. Do you know how low the level was by topping it up until you got a reading? H to L equates to roughly 1 qt/1 L
    Check your level religiously.
    ...Rob.
    Administrator
    May 2003
    The oil light is simply a low pressure light. The second you lose enough pressure to illuminate the light, damage is imminent. I personally think it's one of the most stupid ideas in the automotive world.
    Basically it's a "You just blew up your engine" light.
    The best thing you can do is simply check your oil every 500-1000 miles. Burning 1qt of oil every 1200-1500 miles is perfectly acceptable. Especially in a turbocharged car.
    Moderator Donkey's Avatar
    Da boonies,Va
    I also heard/used the term "idiot light".
    http://en.wikipedia.org/wiki/Idiot_light
    2002 FORESTER S
    1998 FORESTER S
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    Did you say you switched your oil to syth or did you say you changed your oil 5000 miles ago.. I change my oil every 2500 miles at that time I am roughly 3/4 low.. At that point why not just change it to fresh oil.....
    Administrator
    May 2003
    Quote Originally Posted by 4cyturbowrx View Post
    Why?
    Registered User armindk's Avatar
    Dec 2009
    louisville, ky
    Quote Originally Posted by elitex109 View Post
    Add a quart of oil and see where the oil stands on the dipstick. Also make sure the car has been off for a few hours before you check (an hour or two should be fine) and make sure your car is on a flat ground. Typically there is at least 2.5 to 3 quarts of oil below the dipstick which is why you add oil .5 quarts at a time and wait a minute or two and then check the dipstick again to see where the oil is. Remember that you can always add more oil but if you overfill it, then you will have to drain some of it to prevent the crankshaft from whipping it into a mocha late!
    Also you can have your oil light come on even if you have oil in your engine. It's basically a pressure sensor and if the pressure drops below 5 psi I believe (which is way low), it's when the light comes on.
    Registered User hcancino's Avatar
    Oct 2010
    Lafayette, IN
    Quote Originally Posted by Trainrex View Post
    Why?
    The owners manual says to change your oil every 3750 miles. I would understand every 3000 but yes why every 2500 miles?
    2011 obsidian black pearl limited wrx
    Nov 2003
    philly
    It's just a peice of mind for myself....... My mechanic thinks I am over protective... But it just comes down to I like keep the oil clean and full..
    Registered User rwnyce1s's Avatar
    Mar 2010
    NJ
    Better safe then sorry...
    NYCE1S.com
    www.Nyce1s.com
    Follow us on our Facebook fan page:Nyce1s.com
    Follow us on Twitter:@Rwnyce1s & @Nyce1s
    92' Bubble with K20 swap.Tuned by Yosolo with KPRO
    02' WRX with basic bolt-ons(for now)
    Administrator
    May 2003
    I don't know about that. Manufacturers are slowly admitting that the 3000, and even the 4000 mile oil change intervals are just a ploy to make money. Most cars on conventional oil and a decent filter are perfectly safe changing at 7500 miles. Many vehicles these days call for changes between 9000 to 12000 miles. Changing at 2500 is basically throwing money away.
    <steps off soapbox>
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    This. Acura is now proposing an oil change interval of 15,000 miles on the new TSX
    That said, I still change my oil every 3500 miles....
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2009
    Makes me scared to find out what the new, improved replacement ploy might be...
    ...Rob.
    Administrator
    May 2003
    Quote Originally Posted by mudferret View Post
    I'm sure there are many of them already in place...
