Searching around, it appears the people with this problem seem to have misaligned the input shaft upon reinstallation. Is your steering wheel off at all when driving straight?
This is a discussion on Traction control after steering rack bushings within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed the whitline steering rack bushings. Now my tcs and hill assist lights are on. Any ideas? Sent ...
Sent from my Droid using Tapatalk
Cody
Good news, everyone!
No, its straight as far as I can tell. I mis-marked it, so I kinda had to eyeball it, bit the few miles of driving I did were straight.
Gotcha, it seems that even being off by a small amount can cause issues though. Others have reported needing to change otu the clock spring assembly in their steering columns due to a ribbon in there having been torn because of a misalignment. Hopefully your issue is not as bad as that, but you may want to get it professionally aligned.
Cody
Got it, thanks.
You might have a steering angle sensor code in there, as mentioned even a slight misalignment can throw a code, I have seen it many times...
