Results 1 to 15 of 15
This is a discussion on Un-rev in gear? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Start the car, let the revs drop (due to temperature increase) to about 1250-1500 (not tried higher/lower than this range), ...
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    Un-rev in gear?
    Start the car, let the revs drop (due to temperature increase) to about 1250-1500 (not tried higher/lower than this range), with clutch down, pop it into 1st. The engine slows down by about 250rpm...
    ...why?
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Apr 2007
    8000' up in Colorado
    Because the transmission stops spinning so the engine has less load on it, which allows it to run with ease at lower RPMs.
    Scott
    Feb 2010
    It does not correspond with the pushing of the clutch (I've tried), it's directly right after I put it into gear. The reason it seems odd is because the engine is still just spinning the flywheel, right?
    May 2010
    Chicago, IL
    Quote Originally Posted by poly_poly-man View Post
    When you put it in gear, the clutch engages just a bit. Giving the engine just a little load, not enough to move the car but it is there. I saw this when you have the car up on jackstands, if you put it in gear, the wheels will start spinning slowly. That tells me that the clutch is still touching the flywheel a little bit.
    Feb 2010
    Quote Originally Posted by monchis View Post
    This seems like a terrible idea - if you sat there all day with the clutch all the way down and the engine on and in gear, the clutch would burn up?
    Why would they design this into the car? Does it mean that we have to adjust our clutches, or is it just supposed to do that?
    May 2010
    Chicago, IL
    No no, it's not nearly enough friction to heat up the clutch. It just touches the flywheel a little, by that I mean very little. It's just because they're so close to each other. Besides, who would sit all day with their car in gear and the clutch depressed?
    Apr 2007
    Sorry, I misread your first post. I thought you were saying before you put it in gear but after you pressed the clutch.
    Scott
    Feb 2010
    so basically, they're designed to be separate, but it's pretty much tolerances that make them touch?
    May 2010
    Chicago, IL
    That is correct, that is why it goes down a few rpms when you put it in gear
    Dec 2003
    Dallas, TX / Sterling, VA
    You're not reading the gauge properly. The gauge starts at 500 rpm. Proper, warmed idle is going to be around 750-850 rpm
    Feb 2010
    Quote Originally Posted by brfatal View Post
    I know this. "I'm in a rush and it's cold out" idle is more like 1k at the least. Each tick is 250rpm. I've noticed pretty much every time, I can let it drop itself to 1250, then putting it in 1st drops it down to 1000 (same with 1500 down to 1250).
    May 2010
    Chicago, IL
    I'm sure she was talking about warmed up already. We're talking about cold idle.
    Registered User Monk_Knight's Avatar
    Aug 2010
    Colorado
    Mine idles at 1500 right after starting, then drops to just over 1k, then when it's all warmed up idles right about 500.
    Feb 2010
    Quote Originally Posted by Monk_Knight View Post
    nope, the first line is 500, the second it 750, where wrx's are supposed to idle. If it really were at 500, your car would be barely working.
    May 2010
    Chicago, IL
    Engines idle between 750 to 850 as stated before.
