power loss at high rpm
Results 1 to 4 of 4
This is a discussion on power loss at high rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, I was driving hone from work tonight and I put the pedal to the floor after the car had ...
    Oct 2010
    Canada
    So, I was driving hone from work tonight and I put the pedal to the floor after the car had a few minutes to warm up. All went well as usual but then it felt like the clutch was slipping. I shifted gears and then it happened again once the rpm's climbed back up.
    I waited about 10 mins then I floored it again, this time watching the rpm's. At around 5k the engine just seems to stop making power for a fraction of a second then comes back, then loses it again and so on. I held the pedal down as I was trying to figure out what was going on and it wasnt able to really get up to 6k. Then the check engine light starts flashing. I immediately let off the gas completely. After about 10 - 15 seconds it went away.
    When I was close to home, I floored it again and I got through first and second shifting at about 6.5k then in third I it started again and I held the pedal down for a 2 or 3 seconds then the CEL starts flashing again, then goes away. Temperature this whole time was just below the middle of the gauge (slightly on the cold side.)
    I have no clue what this could be. And i'm %$@&ing angry as i have only had this car for 1.5 months.
    Info about the car: 2002 WRX sedan. Has a magna flow muffler and unsure of the brand of down pipe. I was told it has a stage one reflash and should make an extra 2psi of boost. Also has injen cold air intake, and HKS blow off valve.
    Until tonight actually I have never seen the boost guage go a hair past .1 MPa which is about 14.5 PSI but tonight I saw it cross it by the width of the needle. It may have gone to .11 or .12 MPa if i were to guess.
    Sorry this is so long but I want to get the best help I can and not leave anything out... I have fallen in love with this car and don't want it to die.
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Oct 2010
    Canada
    Thanks for the quick reply. I read through a bit of both of those and got from it that my engine was knocking maybe. I thought about it and just before this started happening I bought gas at Esso instead of Shell like I usually do so I thought maybe Esso's gas isn't as good.
    I picked up some octane booster from Canadian Tire and it seemed to instantly fix the problem. But then later today when I drove home It started again but now the CEL is just on, not blinking. I turned off the car and turned it back on but the light is still there.
    What now? Buy one of those obd II code reader things?
    Jul 2009
    either buy an obd reader, or if you have an accessport you can use that. Or you can go to an auto parts store and they will normally let you use one they have for free.
    Josh
    Bugeye mafia #300
