How do YOU maintian your WRX?
Results 1 to 8 of 8
This is a discussion on How do YOU maintian your WRX? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Other than oil type (which apparently is mandated by Subaru for me to keep my warranty) and appearance (wax, etc.), ...
    Feb 2010
    Other than oil type (which apparently is mandated by Subaru for me to keep my warranty) and appearance (wax, etc.), what do you do to maintain your WRX? Are there things that you do to maintain longevity other than the recommended maintenance checks? Hook a new owner up with your tips and tricks.
    Administrator
    May 2003
    If you follow the owner's manual maintenance procedures/ schedule and drive it gentle, it will last a looooong long time.
    Aug 2009
    Canada/Ethiopia/Madagascar
    I typically follow the maintenance schedule, but decided to replace the oil pick up tube as added insurance against a cheap part causing an expensive problem.
    I'll also be changing my timing belt, water pump, and pulleys well ahead of the recommended mileage.
    Aside from that I check all fluids religiously/frequently.
    ...Rob.
    Quote Originally Posted by PacoBJuarez View Post
    Exactly what the manufacturer states in the owner's manual and/or any TSBs released.
    No.
    Use authentic or OEM parts.
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Don't mod your car.
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by mudferret View Post
    I will say I have heard of a few guys doing this, I have had a couple come in with no oil pressure, and personally I have never in the thousands of subarus I have wrenched on have seen an oil pump fail..leak yes...but not fail...anyways the pickup tubes I have replaced they all seem to crack right at the weld where it bolts to the block, my best guess is the support for the pickup when tightened distorts the weld a tad and wears over time...this is just my thinking...
    Aug 2009
    I typically ignore the e-hype about everything that can go wrong with our cars. I couldn't ignore the p/u tube however, good marketing by Killer B I guess... Turns out my stocker was fine, although I know a couple of people locally who have had failures.
    ...Rob.
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    i agree with not modding your car, but its pretty difficult to resist. i guess safe modding is probably the best way to do things. if you plan to mod, make sure you have the money to replace or rebuild your motor when if blows up on you and subaru denies your warrantly claim.
    in speaking with the mechanic at the body shop i work at, one thing he pointed out that is extremely important, especially for forced induction vehicles, is to allow the vehicle to warm up sufficiently before going into full boost. i always let my car warm up for a min or so, and i keep it under 3k RPM until the coolant temp gauge has reached normal operating temperature for at least 5 mins. keep in mind, coolant is going to warm up much faster than oil, so even thought the coolant temp gauge may read normal operating temp, your oil may still not be warmed up completely.
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
