antifreeze question
Results 1 to 4 of 4
This is a discussion on antifreeze question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i flushed my radiator over the summer and with winter getting here i've been curious if i have the right ...
    Aug 2010
    Indianapolis
    antifreeze question
    i flushed my radiator over the summer and with winter getting here i've been curious if i have the right mixture so it doesn't freeze. i'm quite sure i'm good but i'm still a little worried. i poured a full gallon of prestone in the radiator and i believe it was less than a gallon of distilled water. then in the overfill i poured some more out of a new container. with this logic i should easily be better than 50/50. i bought a cheap tester at autozone and only 1 or 2 of the 5 balls floated. this is what has me a little concerned. is the tester just cheap and wrong or is my mixture not right? thanks.
    2005 Subaru Impreza WRX Wagon
    Was the coolant a prediluted mixture? Some coolants are sold ready to use; in that case you are lower than what you think in coolant%. If not though I see no reason to worry.
    Aug 2010
    Indianapolis
    About 99% sure its just the regular non-diluted coolant.
    Then you should be at roughly 50/50 like you say.
