This is a discussion on 2011 wrx crazy turn signal within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Experiencing a problem with my passenger side blinker six weeks into my '11. Haven't found anything on clubwrx but have ...
Experiencing a problem with my passenger side blinker six weeks into my '11. Haven't found anything on clubwrx but have seen numerous reports elsewhere.
The turn signal blinks rapidly as if there is a bad bulb (according to the manual). The front turn signal filament is not lighting up while the seconary is flashing at a fast rate (if you look close, there are two filaments on that bulb). So far, this "hyperblinking" has not been consistent and I've had a few instances of regular behavior within the past two days.
From what I gather so far - this is not a bad bulb issue as some reported recurrences after bulb change.. Anyone familiar with this issue or similar electrical problems? Thanks!
check fuses and bulbs. replace as needed.
'02 wrx wagon:
various cobb things here and there.
LoneWolfBugeye #01
Yep, something is up. It is absolutely going to be one of these 3 things:
1 - the bulb is loose or blew
2 - a fuse is loose or blew
3 - the wiring to the headlight housing is loose
Since it can fix itself and work for awhile, I think it's 3.
Steve // 2008 Lexus IS-F // 2011 WRX hatchback (SOLD)
Same problem here. 2011 WRX after a month the front passenger blinker will go out once in a while. It works about half of the time. I'll post if I ever figure out whats going on
Have you tried changing the bulb? Sometimes the filament breaks on one end and will sometimes make contact, sometimes won't, causing an intermittent problem.
you have a new car...just let the dealer figure it out![]()
2011 WRX Limited, DGM; full tint, SPT CBE/STS w/ bushings, RA flaps, Enkei PF01s, Pink SuperTones, and ClubWRX.net stickers!
My Photostream
about.me
I have the same exact problem on my 2011 wrx sedan. I have an appt on Monday with service to have it repaired but I find it interesting that I'm not the only one with this issue!
Mine occurs on the drivers side...usually occurring when the car 1st gets going...I'd be interested to find out what the dealership is doing for those who bring them in...Which I will be doing here shortly after the holidays...
dealer fixed mine today, said he just swapped out the bulb.
car is a few weeks old, kind of frustrating to already have something like this happen. Not the biggest deal but it wasted 2 hours of my day today.
my civic si = 0 issues in 2 1/2 years.
Well, I'm now part of the crazy blinker club. Coming home from work on Fri my left turn signal started it's epileptic behavior. I looked at it a bit and the light is not only faster, but much dimmer than normal. It's raining today so I have to wait until I get home later and am in the garage to look, but I'm going to jiggle the bulbs/wires to see if that does anything.
This is real annoying but at least it's just a nuisance and not something where I can't still drive the car.
