'09 WRX Squeek noise
Results 1 to 15 of 19
This is a discussion on '09 WRX Squeek noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Developed an odd sound. Im getting a squeaking like sound while accelerating. Happens every time while taking off in 1st, ...
    Registered User Willard's Avatar
    Feb 2009
    Camarillo, CA
    Developed an odd sound. Im getting a squeaking like sound while accelerating. Happens every time while taking off in 1st, and gets less and less as I row through the gears, by 4ht its gone. Also tends to do it a tiny bit when decelerating while in gear, same circumstance; less noticeable in higher gears. Almost sounds like the seat is squeaking as weight shifts back and forth (obviously debunked that theory) It sounds like its coming from the interior, but cant really tell. Anyone else have an issue like this?
    2011 Honda CR-Z EX
    Milano Red / Navigation / 6MT
    2009 WRX hatch premium SEM #52 Traded 7/28/11
    Kartboy STS & bushings // RedlineGoods Shifter & E-brake boots // Muffler delete pipe // Window tint //
    Feb 2009
    Camarillo, CA
    Guess Im the only one =( oh well.
    2011 Honda CR-Z EX
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    i have a 2010 rex, and i wouldnt say mine squeaks, its more like a whistle. its has been there every since i bought it, and its the turbine in the turbo that is making the sound. it gets louder the higher boost goes.
    im not sure if that is what you are hearing.
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
    Feb 2009
    Camarillo, CA
    Na, not it. My drivetrain whines like mad, but its done that since new. Na, this is a recent issue. Just gonna deal with it, turn the radio up and give the car back in 3 years when the lease is up.
    2011 Honda CR-Z EX
    Feb 2009
    Camarillo, CA
    Got it figured out. Dont think its fixable. Took the center console apart and rolled back and forth a few times in gear. Noticed my shifter would flex downward causing the noise. Think it has to do with the harder shifter bushing. The old rubber ones would give under the stress, since these do not, they flex the entire assembly causing a squeek of sorts. Kinda odd that it took a while for it to develop though.
    2011 Honda CR-Z EX
    Feb 2010
    Central, NC
    i may have the same noise.....
    I have 2010 wrx with a ss and spt replacement shifter bushings. Since it has started to get cold here a sqeaking has started that matches your description exactly.
    My sqeaking seems temperature dependent and much more noticeable in the morning when cold. It disapears when the temperature warms up or the car has been driven and has gotten hot.
    Feb 2009
    Camarillo, CA
    Could be temperature dependent. I added some sound deadening foam under shift boot, it helped a lot.
    2011 Honda CR-Z EX
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by Willard View Post
    The only squeaks I have witnessed in the new WRX's is the release bearing...
    With the vehicle running at idle when you just start to depress the clutch right at the point you start loading the release bearing up you hear a tiny squeak, I did have to do some of these under warranty and the only fix is obviously replacing the throw out bearing...Ill keep my eyes out for an issue like this...
    Registered User hisdigness's Avatar
    May 2010
    So Cal (Torrance)
    I have an annoying whistling sound when depressing or releasing the clutch. However it only happens when the car is cold and the outside temp is cold. I am taking it to the dealer next Monday. I think it might be the throwout bearing...which sucks since the car is only 4 months old with 6k miles on it. I don't drive like a maniac either and always let the car warm up. When warm its fine. I will report back next week.
    Mar 2011
    I have the same squeak noise on my car. 2011 WRX with 19.5k miles. It started doing it when the weather started to become cool. Wow it's annoying. Coming from a 2001 BMW that had no noises whatsoever, I'm pretty pissed.
    Registered User SamXp's Avatar
    Nov 2010
    Winston-Salem, NC
    My 2011 WRX has done this in cold weather since I bought it. It has the dealer installed short shifter and SPT bushings. I've brought it in twice. First time they lubed the bushings and it got slightly better. Second time, they replaced a bushing and now I think it is worse.
    Feb 2010
    Central, NC
    Waterproof Grease was the answer....
    Waterproof Grease was the answer to my squeaking. The dealer greased it but it didn't last.
    I regreased it with a water proof, tacky as hell, wheel bearing grease last winter. It was a pain taking the heat sheild off but not a sound since.
    Nov 2010
    Winston-Salem, NC
    Quote Originally Posted by msennati View Post
    Where did you apply the grease??
    Feb 2010
    Central, NC
    on the squeaky bushing......
    on the squeaky bushing????
    1. Put car up on Ramps or Jack stands (a lift would be nice).
    2. Go under car and find Transmission. The bushing is somewhere on top. Remove the exhaust heat shield unless you like cut up hands and arms.
    3. Two bolts hold the bushing. I took off the bolts but I didn't remove the bushing. I just removed the bolts so the bushing was loose.
    4. Apply Grease.
    5. Put it back together.
    None of this is hard but if you are not mechanically inclined and can not do things by feel, get someone else to do it.
    Nov 2010
    Winston-Salem, NC
    Thanks. I wonder if it is accessible from the top?
