Results 1 to 15 of 19
This is a discussion on Whining coming from car within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So today my 02' stage4 rex developed a whine. It occurs in specified conditions. It always happens when accelerating. If ...
    Registered User DTR rex's Avatar
    Jun 2003
    Chi-town, IL
    If I let off the gas it still continues. HOWEVER, if I put it in neutral and stay off the gas it goes away.
    Strangely though, if I put it in neutral and rev it happens
    Can't locate exactly where it's coming from but I am thinking it must either be a belt or the turbo. First thought it was the tranny, but if it was the tranny it wouldn't whine in neutral while revving right?
    Car has 110k on it and all belts are recently changed aside from timing belt.
    Thanks
    Just call me Clark Kent
    Offical Body Guard for the Bugeye Mafia.
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    Time to do the timing belt anyway. If it's whining in neutral it is not your transmission. I would check all the belts first.
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Administrator TheJ's Avatar
    Dirty South
    I would be inclined to agree with Sonic.
    -The J
    New Members, CLICK & BOOKMARK these links:
    Apr 2007
    8000' up in Colorado
    It could be your transmission. There's still parts of it spinning even in neutral. The gears connecting it to the axles/driveshaft are just disengaged. I hope it's not that...
    Scott
    Registered User eastbaywrx's Avatar
    Jun 2010
    What kind of whining is it? I experienced this recently too under the same conditions you listed. It was very high pitched, and couple guys on here said it was a boost leak. It turned out to be exactly that, maybe that is what is causing you to hear a whining during the situations you listed.
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    At first I thought you were referring to significant other!
    Hopefully it's not a transmission death whine!
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Jun 2003
    Chi-town, IL
    It only whines in neutral if I hit the gas (rev). If I'm in neutral just cruising it goes away.
    Jun 2003
    Chi-town, IL
    Quote Originally Posted by eastbaywrx View Post
    Yeah, I was thinking a boost leak too based on the fact that in neutral it goes away but the second I rev it starts again.
    So basically it has to be either a boost leak or a belt?
    Boost leak might make some sense since my car has been feeling kinda sluggish lately.
    Best way to check for a boost leak?
    Jan 2009
    Central PA
    Quote Originally Posted by DTR rex View Post
    My tuner does a boost leak test...do you have any good tuners near you?
    If you have an air compressor and a regulator you can look up how to build a boost leak tester and do it yourself too! There are a few diy threads on nasioc.
    Subaru Guide
    Aug 2002
    Virginia Beach, VA
    Is it inappropriate to make a joke on this thread? I mean, whenever I get a whining tranny in my car, I just kick her out and pick up another one...*rimshot*
    Does it sound like synchro whining?
    zax
    zax is offline
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    It must be those PPGs you put in
    I bet it's synchro whine. My car has been doing the same thing, especially noticeable in the cold. In first, if I put the clutch down, I hear the whine. If put in neutral and let the clutch out, no whine.
    Facebook me here
    Jun 2003
    Chi-town, IL
    Whine is louder now and started on start up. Sounded a lot like a belt at idle. Probably the timing belt then, huh?
    Registered User wo^tron's Avatar
    Jun 2010
    Naples, FL
    power steering maybe? my PS pump just bit the dust, but a few months before any "feelable" symptoms showed up (stiff steering wheel no clutch assist etc) I'd get some pretty bad whining, it would start on startup and seemed throttle related
    Put aside the everyday world and come with us
    Into the realm of imagination
    The middle ground between light and shadow
    Registered User KnightFury's Avatar
    Sep 2010
    salem, oregon
    Quote Originally Posted by Timdog1650 View Post
    +1!!!!
    Jan 2011
    My car is has a whine that sounds like what you described. Whines when you rev it and follows engine RPM. It does not chance in gear or out, does not chance when moving or not. So, mine is not trans related. My next idea was the belts and all they are connected to. (It sounded like an alternator going out but I could not pinpoint the whine with the hood up). I removed the two accessory belts and started it up.... guess what, whine still there. So that rules out all that equipment. (I replaced the belts anyhow.) Could it be the turbo? I suppose it could be but I doubt it. The car runs just as well as it ever did, also I would think if it was the turbo it would not start whining till it spooled a little. Mine whines right off idle and starts as soon as I start the car before the turbo ever builds any pressure.
    Also I might add that the car has not thrown any codes and is completely stock. My next guess was the timing belt. Car has about 90,000 on it so it was due anyways. I got a new kit for the belt and all the tensioners and pulleys. The kit also had a water pump. Last weekend I did the chance out . ( someone on here posted a how too...thank you for that it was very helpful!!) The only thing I did not chance was the water pump. Mine looked fine, wasn't leaking and had no shaft play.) I put it all back together and guess what.... still whines!
    This porb didn't help you much, just throwing it out there. Anyone have any other ideas what it could be?
