My bugeye is cursed :(
Results 1 to 15 of 16
This is a discussion on My bugeye is cursed :( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have broken more bolts on my car than I have fingers and toes. Unfortunately, this one is the worst... ...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Today, I was taking off the stock brackets to replace my steering rack bushings. I had used PB blaster on the bolts overnight and a lot this morning. Using a 16 inch breaker bar, I was able to break loose 3 out of the 4 bolts holding the brackets. The 4th bolt, however, sheered right at the head. I successfully drilled the bolt, but can't separate the thread from the bolt metal. Looks like I'm going to have to pull out my tap and die set Anyone have any ideas before I resort to tapping a new thread?
    Also, does anyone know what the original thread is on these bolts?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Nov 2009
    I am sort of confused on your situation but I always suggest a lot of heat in these situations. Have you tried to heat of the bolt yet?
    Apr 2007
    8000' up in Colorado
    If you can't break a bolt that size loose with a smaller wrench, then the breaker bar is pretty likely to shear it. You need to invest in an impact wrench.
    Scott
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    ^^ This.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User KnightFury's Avatar
    Sep 2010
    salem, oregon
    + 1 on heat that always is a big help,...
    one idea my brother(a mechanical genius) does if you have the avl to do, he hat this lil T lookin thing and before tapping w/ the drilled hole , weld that lil T inside, heat then turn, to me it always looks like childs play when he does it and turns like butter, each time im amazed... lol good luck
    Feb 2010
    SL,UT
    Ouch... that sucks... if its cursed run some distilled holy water through the cooling system and when your trying to undo things shout "the power of christ compells you"
    Hawk-Eye Alliance #801
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    Quote Originally Posted by oguitar View Post
    heat and harmonics.. use penetrant (as you have) .. get it hot (cherry if you can) .. and a lil tapppy tap tap (or a impact wrench on a really low setting .. sized according to bolt size)
    Between the heat/penetrant/vibration they usually come loose pretty easy.
    Aside of my yota and the wrx (the only "new" cars I've ever owned) I'm used to working on old rusty stuff.. the merkur was a 86, my old jeep was a 85 and my first scoobie was a 88. All northern "seen many winters" vehicles. I broke one bolt on the jeep, and later realized that a po had welded the back side of it to stop it backing out.. so even then, not completely my fault. Never broke any on the merkur and that sucker was RUSTY underneath. Had every inch of that car apart and back together.
    Just use those three ingredients and you'll not break a bolt again. .. well, hopefully not lol.
    YES.. another thing I forgot to mention is to attempt to use the smallest tool possible to do the job and work your way up. I know guys that always use the mammoth wrench or bar first for med/small stuff and wonder why it always breaks. ... meanwhile I'll start with 1/4" for small stuff and usually 3/8" for med to light larger stuff. I'll only use 1/2" tools for big stuff and the advice on the impact wrench is spot on.
    Remember also that you dont need air for an impact wrench (though air ones are much cheaper) .. there are electric/battery powered ones that work just as well. Pricey but functional. A 1/2" variable unit should cover every car need you'll ever have.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Dec 2003
    Dallas, TX / Sterling, VA
    I share that same curse. I break bolts all the time. And I'm still new to this "rust" thing to make it worse.
    My car's curse has returned as well.
    -Squeaky belt that's been adjusted twice so far
    -Suddenly running so rich that raw fuel is coming out of my exhaust.
    Oct 2009
    Rust BLOWS .. dude I am SO happy to work on a car that doesn't have rust. I'll be very sad when it starts to develop it. All cars do.. my beloved 2010 will be no different given 4-5 years from now worth of all season driving.
    OH, Zack.. another thing that helps with broken bolts.. reverse cut drill bits. It sounds nutty but they work very similar to a easy out but dont have the same tendency to break off in the hole.
    SWP 2013 FRS
    SUCH IS MANGO!
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    I got tired of the squeeks, high miles, headaches trying to do simple things, and the overpricing of parts for my bugeye and traded it. On topic though, if you cant get it with either an adjustable socket and a hammer, use an impact. I was lucky enough that where I did all the work to my car (at work) I had access to any size bolt or nut I needed. I love being a lift mechanic, 2 or 4 post hydraulic lifts make anything to do with suspenion or exhaust 10x easier. Sorry to hear about your bolt situation.
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
    zax
    zax is offline
    Nov 2008
    Alright all, forgot to give an update. drilled and tapped the hole to 3/8" and ironically during the tapping process the original bolt separated from the original thread and I was able to use the stock hardware. Disaster averted!
    But I am sick of this occurring whenever I perform any work on my car. I'm thinking of just dropping the cash and purchasing a Dewalt electric impact wrench
    http://www.homedepot.com/webapp/wcs/...66&marketID=34
    I'd like to invest in air tools, but can't really store the compressor anywhere seeing as how I live in an apartment, and since I live on the 4th floor, I don't have access to any electrical outlets... thoughts?
    Facebook me here
    Administrator
    May 2003
    I have two of these.
    I love them so much, if given the chance, I would have relations with them.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Trainrex View Post
    I want. But they are almost twice the price of the Dewalt...
    Facebook me here
    Administrator
    May 2003
    Buy holy poop on a stick do they work well!
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Where do they sell that?
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
