Close the gas cap!
Check this link:
what is this? between manifold and intake (post MAF)
This is a discussion on P0442 evap system small leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys about a week ago I got this code when the check engine light went on. I cleared the ...
Hey guys about a week ago I got this code when the check engine light went on. I cleared the code and the light was off for a week. This morningthe check engine light came back on. I haven't checked but I'm assuming it's the same thing. Anyways, I am wondering if people have had this happen to them before? And what would I have to go through to fix this
Close the gas cap!
Check this link:
Facebook me here
Originally Posted by Mikie13
Facebook me here
Oops. Sorry I didn even see the one post in that thread. So I should check those valves donkey was talking about?
Also this is a pretty dumb question also but what exactly is the evap system.
it recovers/stores and removes fuel vapors. i used to get it never found a leak.. i just disabled that dtc with my ecu flash.
If you have everything under control you're going too slow.
Bugeye Mafia #218 XPT gm bcs stage 2
my mods
HIGH MILEAGE CLUB
ASE CERTIFIED MASTER TECH.
http://www.aa1car.com/library/evap_system.htm
Enjoy.
EDIT:
Or maybe not... quoted from text:
I didn't know that there were two codes, one for small leak and another for large leak (P0440). Scratch my original gas cap theory... But I would still check your purge valvesThe code you don’t want to see is a P0442. This indicates the system has detected a SMALL leak, but small leaks can often be a BIG problem to find.......And if you have a P0442 small leak code, you’ll probably have to take your car to a repair shop that has a smoke machine
Facebook me here
