Results 1 to 12 of 12
This is a discussion on 100k tune up HElp! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi i need to change my timing belt and water pump since i reached 100k miles, whats the best way ...
    Registered User jaap's Avatar
    Jul 2010
    Alabama
    100k tune up HElp!
    hi i need to change my timing belt and water pump since i reached 100k miles, whats the best way to go? One of my friends told me he got a kit with everything for $220 at slowboyracing.com but i cant find the kit can anybody tell me whats the best kit and affordable to buy and where? thanks and i have searched..thanks
    Nov 2009
    This is where I bought mine.
    http://www.jscspeed.com/catalog/Suba...7_WRX_STI.html
    Try a vendor here on clubwrx first.
    Jul 2010
    Alabama
    100k tune
    Okay thanks
    Jan 2005
    Eh, whaaaaa?
    I can see that price being for the belt and the water pump alone (though still rather cheap), but that won't include the tensioner or any of the idler pulleys, which I would highly recommend you replace.
    Cody
    Jul 2010
    Alabama
    I googles and I found out the I also should replace the thermostat is there anymore good website where I can buy good product for my 03 wrx
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by jaap View Post
    For a thermostat ONLY use the Subaru model. It may be a bit more expensive, but not by much, but it's basically the only thing that will work correctly for your car.
    Cody
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    Quote Originally Posted by Anub1s View Post
    what about the number of 160 degree fail-open thermostats (grimmspeed, etc.)? I would argue that this would be a better option than oem.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Quote Originally Posted by poly_poly-man View Post
    On what basis would those be a better option than OEM?
    Jan 2005
    Eh, whaaaaa?
    Argue all you want, evidence suggests otherwise. Regardless of how they fail, they still fail, more often than the OEM's.
    Cody
    Feb 2010
    http://www.iwsti.com/forums/2993533-post520.html
    I have a hard time finding failure rates... mind pointing horror stories my way?
    Jul 2010
    Alabama
    So I should buy the oem instead of an aftermarket
    I use the OEM thermostat. I also use OEM gaskets for the water pump and thermostat, OEM crank or cam seals if needed (I don't know or care whether there are imitation parts available for those) and I'm thinking about the newer Subaru blue coolant next time it's due. I will use the Subaru conditioner.
