Did you adjust the spring?
http://www.cobbtuning.com/products/?id=5065
ADJUSTMENT
Spring Preload - Spring preload determines the pressure differential across the BPV piston required before the BPV opens and releases the pressurized intake charge. The COBB XLE BPV can be adjusted by loosening the locknut and turning the allen-head shaft clockwise for more preload or counter-clockwise for less preload. Once preload is set, the locknut is retightened and ensures the adjustment is secure.
LinkBack URL
About LinkBacks
