What I assume is "limp mode" issue. Not solved info in post #1
Ok nothing is solved so let's start fresh.
*new info* Car runs like a champ with MAF unplugged, issues are only with MAF plugged in. MAF and ECM have been replaced, original ECM is back in the car as it saves me $$$
It HAS to be something the MAF is affecting but I can not for the life of me figure out what it is...
Subaru had the car for 3 weeks and the only idea the tech line gave them that they didn't try was oil control valves. *new info*
Ok long story short I flashed Cobb stage 1 and this arose, tried many things and the issue remains.
Car runs perfectly up to 4500 rpm then it just hits a wall, feels like fuel cut or hitting the rev limiter.
2006 wrx tr
I have tried flashing stock map, flashing stage 1 again, completely removed the AP from my ecu.
New plugs
New fuel pump
New fuel filter
New bcs
New MAF
New battery
New MAP sensor
New front O2
Disconnected battery for 12+ hours.
No vacuum leaks of any kind.
Not one CEL.
The problem persists unchanged.
Sorry I've been absent lately, having some family issues. I was able to take some logs today on my way up to the hospital... I really hope these can help this problem get sorted.
I'm struggling with how it can run perfectly with the MAF unplugged, but all screwed up once you plug it in. Since the MAF is good, that tells me it's the ECU that is not reading correctly what the MAF is sending it.
Dumb question: Are all of the connections on the MAF plug good where they plug into both the MAF and the wiring harness? (Or maybe it doesn't plug into the harness and the wires from the plug on the MAF run all the way to where they terminate in the main harness, I can't remember.) Any of the wires clipped or frayed or otherwise worn, possibly grounding out?
Could it be a bad 02 sensor feeding bad information back to the MAF, causing it to make inaccurate corrections to the air/fuel ratio?
Maybe a bad EGR valve or some part of that system?
Just brought it home from the mechanic. Yeah the MAF wires look great. Changed the front O2 already. I'm completely out of ideas, I might have to just dump it at Subaru for a while since I've got way too much going on to rip it apart again.
I think I'll make one more run through of hoses and wires tonight though. Maybe something is loose on/near the ECU I dunno.
You guys rock for all the help though, I hope I can repay it someday.
I have flashed back to the stock map. I've gone back and forth a few times just to be sure.
Also, I checked for leaks 3 or 4 times and the shop had it for a week, they also checked, as did Subaru.
With stage 1 the issue occurs ~3200 RPM, stock ~4500 RPM. MAF disconnected runs like it should.
The dealership can't get to it for about 2 weeks so I'm trying to squeeze in some attempted fixing time between work and mom in the hospital. Not easy.
Are you sure the other MAF you tried in it was the correct part number? Or that it wasn't broken?
If all you're changing is whether the MAF is plugged in, then there's really just a few components that could be causing the issue:
MAF - Bad sensor or wiring - See question above
ECU - Bad ECU - possible
02 - Bad sensor - Already replaced, so should be ok.
Piping - Leak - Checked already, so should be ok.
The new MAF was purchased directly from the dealership and is the correct part number. I'm going to follow all the wiring and inspect it when I get a chance.
There's a lot of guys like me and Donkey that are pretty hardcore tuners and car modders so if we can't figure it out, even from internet posts, then you've got a really hard problem. He's stronger on Subarus I bet but I'm probably stronger on a wide bunch of cars. But it just doesn't make any sense. I'd love to see/drive the car in person. That would help me a lot, but that's not going to happen.
Well I take that back maybe I could. I'm heading to Cali some time in the next month or two and passing through your area.
That's a bad ass offer! Though I would hope I don't have to take you up on it... I hope it's fixed soon. Though it has been a month and a half already.
Any way to test the ECU without needing another one to swap?
