If it has an automatic transmission suspect the transmission. If it has a manual gearbox suspect the clutch. This is only from the description you've given -- revs climbing then dropping without the car following accordingly.
This is a discussion on Help me diagnose this... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've got a 2002 WRX (secondhand) with about 140k miles. Recently (maybe the past two months) I've been having a ...
I've got a 2002 WRX (secondhand) with about 140k miles. Recently (maybe the past two months) I've been having a strange problem.
Basically, when I'm gentle with the gas nothing is wrong. But whenever I put the hammer down (and by that I mean anything from "moderate acceleration" to "pedal to the metal"), I slowly accelerate followed by the engine racing and then falling back into the proper RPMs which is when I get full power. At first, I thought it must be transmission slip, but AFAIK, this would mean NO power to the wheels, and the car DOES accelerate the entire time. So then I thought maybe it was a boost problem, but I can hear it boosting at the appropriate time. So, somehow, some energy is being transferred to the wheels, the engine races (with no power change) the rpms go back down and I've suddenly got full power.
What gives?
It's a manual, but it only happens under certain circumstances. And I thought I'd lose all power if there was slip?
After the first reply suggesting the clutch, I started looking around, pricing out what I'd need. According to the "how hard is this to do myself?" thread, I should be able to do it myself, as long as I do it before it gets any colder. So, if I just buy an OEM clutch kit, I won't have to buy or replace anything else, right? Or is this more complicated than that?
Facebook me here
Originally Posted by Mikie13
I've never done anything to this particular car, but I've always been able to take a set of directions and achieve the desired effect when making a repair. Most difficult? Hell if I know. I'm going to find some tutorials on it before I go ahead and try to do it myself, but financially it's really my only option. Between my limited experience and my dad's vastly superior experience I'm sure it can be done. I just have to find time to drive down to my parents'.
Honest answer...
I'd give yourself a weekend to do it then. Yes, you can follow instructions, but Murphy can be a *****. Have a buddy available too.
Sure you can do this, it's not rocket science.. (Subie science???)
You will need:
- A garage or flat surface
- Associated support equipment (tools, jack, stands, safety gear, etc.)
- Replacement clutch (Exedy is a good OEM replacement)
- New OEM flywheel
- Throw out bearing
- A good DIY or Tech Manual.
- Clutch fluid. Might as well flush out the old fluid.
- You have to drop the tranny, so maybe you could replace the shifter bushings with Kartboy's
I'm sure I missed something...
06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
What's the best way to purchase this stuff? Online would be my guess, but I don't know anything about who would have the best prices and business practice.
FastWRX is reputable, but certainly not the only source (but it is on sale):
http://www.fastwrx.com/exsicl.html
OEM flywheel from you local Subaru dealer or SubaruGenuineParts.com and search the OEM catalog.
I would stick with an OEM flywheel for your stock car.
I would not resurface your current flywheel that has 140k on it.
Or upgrade to a lightened flywheel, your there replacing it anyways and imo was a noticeable differense as to responseI would stick with an OEM flywheel for your stock car.
Facebook me here
It wasn't brought up but after 140k miles your car should have been through:
- One timing belt change (plus other belts)
- Two sparkplug changes (if using iridium plugs, more with copper)
- Four coolant flushes
- At least a couple tranny and rear diff change
- Two brake fluid flushs
- One clutch fluid flush
- One power steering fluid flush
- One AC service
- Many engine oil changes
I have an 03 andhave only experienced awesome things, i have heard of the phantom code if he goes down to say 8lb and yes w/ his applications that would not be wise but a switch to 11-15 would be a noticeable difference, the main reason i did it was when replacing the last bolt on flywheel got stripped beyond all hope so instead of a re-surface i had to grind it off thus needing a replacement so i went lighter and couldnt be happierWhat Pav is suggesting is a good idea... stick with the OEM flywheel with a stock car. With Bugeyes, lightened flywheels can cause phantom misfire CELs. If the OP is stuck without EM, he has to take it to the shop to clear the codes.
Its preference and has to do w/ what th op's goal for the vehicle is but personally it was something that improved for the applications i had and for what i was to do down the road and have accomplised now.
Either way good luck OP![]()
