Results 1 to 4 of 4
This is a discussion on Gauge cluster lights go on and off intermittently within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I'm looking at getting an 02 wrx wagon. This car is sick, the only problem is that the owner ...
    Registered User frflcraig's Avatar
    Nov 2010
    So I'm looking at getting an 02 wrx wagon. This car is sick, the only problem is that the owner says the lights on the gauge cluster sporatically go off. He thinks it should be a simple fix and that it might be a loose connection somewhere that occured when he put the sound system in. Does this sound like an easy fix? (fuse maybe) or should I be worried about a more major problem with the electrical system. I've read about similar problems that led to more electronics failing. What do u think? Should I be weary?
    Jul 2004
    Seattle, WA
    It's tricky business tracking down a loose wire.
    It's not a fuse.
    Nov 2010
    Quote Originally Posted by SeattleJeremy View Post
    It's not a fuse.
    Do you think it could be an indicator that there's something more serious wrong with the overall electrical system?
    Registered User KnightFury's Avatar
    Sep 2010
    salem, oregon
    Quote Originally Posted by frflcraig View Post
    If there is light issues after wiring something that was not done professionally than he may have tapped into somewhere he prob shouldnt and its tough to say... could be other things he has done 1/2 @55ed as well, most things like that sound more like a ground issue, use a voltometer and see where your loosing current may not be abel to easily track that wire but if its stereo related then the issue shouldnt be too deep.. good luck
