02 wrx crank but no start
Results 1 to 10 of 10
This is a discussion on 02 wrx crank but no start within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; A couple of days ago i finally put a new but used(if that makes any sense what-so-ever) ej205 in my ...
    Registered User RugbyJKC10's Avatar
    Aug 2009
    Ft Collins, Co
    A couple of days ago i finally put a new but used(if that makes any sense what-so-ever) ej205 in my 02 wrx. Supposedly the engine has around 40,000 on it. We never touched the timing belt at all, intake manifold came with the engine. We put brand new spark plugs in and gapped them around .28-.30. I can hear the fuel pump feeding fuel and I know that the spark plugs are working. It cranks for a while but never starts. Any suggestions on where to start?
    Jan 2005
    Eh, whaaaaa?
    Check every sensor you possibly can. Most notably, the crank position sensor, and the TGV sensors. Check for fuel pressure, make sure your lines are all hooked up correctly.
    Cody
    Aug 2009
    Ft Collins, Co
    Sensors are all plugged in, grounds are good, battery is fully charged, fuel pump is feeding fuel I can hear it start up when I put the ignition into on position. Can a bad cam positioning sensor or knock sensor cause a no start? the car cranks just fine but just wont start.
    Feb 2010
    SL,UT
    Did you happen to hear the engine run prior to the installation?
    Hawk-Eye Alliance #801
    Aug 2009
    Ft Collins, Co
    Sadly I did not but the seller told me he had gotten it compression tested prior to taking it out. The seller was a subaru junkyard owner but he said the engine was out of his personal car and he had to part out his car because of an accident if i remember correctly.
    Feb 2010
    SL,UT
    Quote Originally Posted by RugbyJKC10 View Post
    Hmm... as much as I hate to say it... it might be a bad engine... an engine wont start for 2 reasons 1. Its not getting fuel 2. Its not getting air.... so you said it is getting fuel so id do what was suggested earlier and triple check everything (connections, wiring, lines)... good luck...
    Aug 2009
    Ft Collins, Co
    alright thank you for your help
    Registered User shorty38's Avatar
    Aug 2009
    Minnesota
    check the crankshaft pulley on the timing belt. mine had missing teeth and did the same thing as yours. since it was maybe in a accident then it possibly could of broken them off.
    Moderator Donkey's Avatar
    Da boonies,Va
    Do a compression test and check the cam timing. Also make sure the coil packs are hooked up right. Black connectors to back cylinders and white to front.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2015
    I know this thread is 5 years old but did you ever find the problem? Im having the exact same issue
