Is it motor oil or gear oil? I can't tell from the pic.
This is a discussion on Oil Leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey Guys, I did an oil change on my 02 WRX a couple weeks ago. This is the second oil ...
Hey Guys, I did an oil change on my 02 WRX a couple weeks ago. This is the second oil change since I bought the car and I decided to put semi synthetic 5w-30 instead regular mineral oil. I noticed some oil spots on the ground here and there and found that the oil was coming from a part of the car that I am unfamiliar with. Anyone know what this is from the picture? Is this a common problem on WRX's?
Thanks, Braydon
02 Silver WRX
It's actually power steering. After further investigation, it was the fitting above that mount that was loose. Tightened it up this morning, we'll see if it keeps leaking.
Braydon
02 Silver WRX
