Results 1 to 5 of 5
This is a discussion on Something is wrong within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok when I started my car it sounded much deeper than usual, also when I tap the throttle, I get ...
    Registered User frypod's Avatar
    Nov 2009
    Great Falls, Montana
    Something is wrong
    Ok when I started my car it sounded much deeper than usual, also when I tap the throttle, I get a high pitch squeak that sounds like a BOV coming from the turbo area. Exhaust leak? Not sure if this is too vague but this is the best I can describe it.
    Edit: I just went out and revved it in neutral. It sounds like it's sputtering when i rev to about 3.5 - 4K.
    Noah | Bugeye Mafia #301
    02 MBP WRX Wagon "Annabelle"
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    An exhaust leak will be a hiss before turbo and loud and nasty garble after the turbo. Plus you'll smell the exhaust in your car or anywhere more than the rear of the car.
    It may be a small exhaust leak, post turbo. Stock exhaust?
    Nov 2009
    Stock everything, yessir
    Sep 2008
    NWI
    Then I am going to first guess it may be an exhaust leak. Somewhere mid car. If you can take a peek underneath while it's idling, you may see some water dripping (if started cold) or steam where the leak is.
    Nov 2009
    so new update: I took her out tonight and I'm gonna correct myself. It grumbles and clunks when I shift gears. and it's the most grumbly in 2nd. this sounds like a tranny problem rather than an engine problem
