wiring problem
Results 1 to 12 of 12
This is a discussion on wiring problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i just did a engine swap on my 02 wrx. everyting is hooked up. all the wires plugged up. i'm ...
    Registered User niloc1347's Avatar
    Jun 2010
    houston
    wiring problem
    i just did a engine swap on my 02 wrx. everyting is hooked up. all the wires plugged up. i'm having two problems.
    first problem is this when both ports on the battery are plugged up the fans come on and stay on. they turn off when i go to start the car.
    second problem is the car won't turn over. it doesn't even try. i'm no expert but this seems backwards. i've been wracking my brain and looking over my wiring setup and still can't find a thing. any help.
    Registered User fortunesk89's Avatar
    kenosha wi
    batt. volts? check wires with a wire diagram, id start at the fan wires and colors.
    2002 plat. silver wrx
    Jun 2010
    houston
    battery is brand new optima yellow top. 12v. tested. checked wiring diagram already and wires. i even went through each one unpluging them to see if any would make the fans stop. nothing
    Are the diagnostic plugs under the steering column plugged into each other? If so, unplug them.
    Jun 2010
    houston
    i'm sure they are cause i didn't touch them thoughout the entire swap. i like to know the whys behind the whats so i gotta ask why unplug them?
    Because if you plug them together, the car thinks you are going to perform diagnostics. One thing it will do in that case is cycle the fans. Check the plugs and make sure they are not plugged together.
    Jun 2010
    houston
    okay i'll check them. after i get the car going i assume i plug them back together?
    No. You leave them unplugged.
    Jun 2010
    houston
    okay another question. why would they be plugged together in the first place?
    Someone would have had to do so, probably to run diagnostics. If you have not, then this is not your problem.
    Nov 2010
    Are all the grounds good? I had close to the same problem and it ended up being a ground.
    Jun 2010
    houston
    a ground it was. i had a ground plugged into the positive terminal of the battery. thanks for ya'll for the help
