help turbo!
Results 1 to 5 of 5
This is a discussion on help turbo! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my car has 30k miles, I review the right car, use the oil that Subaru recommends and I'm not very ...
    bwc
    bwc is offline
    Registered User bwc's Avatar
    Apr 2008
    help turbo!
    my car has 30k miles, I review the right car, use the oil that Subaru recommends and I'm not very Caned car ever. my turbine that smoking sometimes, but I think that it is not bad, could be what?
    If the smoke is external, and comes out from the turbo into the engine bay, it could be an oil leak or a water leak, and it could be from either of the lines that feed the turbo oil or water -- or from another source nearby that leaks under pressure onto the hot turbo.
    If the smoke comes out the exhaust pipe it could be a turbo seal problem I suppose.
    bwc
    bwc is offline
    Apr 2008
    the smoke out the exhaust
    It does not have to be the turbo. Is the motor in known good condition? Does the PCV system work correctly?
    bwc
    bwc is offline
    Apr 2008
    the engine is good. And as I see that the system and PCV valve is working properly?
