IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!! - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 95
This is a discussion on IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; You cannot tune for it. You can just disable the DTC's....
  1. #76
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
  3. #77
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    thank you.
  4. #78
    Sep 2012
    Colorado Springs
    Still no progress on my misfire situation. Haven't driven the car in a week but it's still not acting like any misfire I've ever heard or felt. Runs great. What is the possible worst case scenarios? I'm taking it to the shop Monday...trying to wrap my head around the wrist possible stuff....
  6. #79
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Just like to say thanks Donkey. I had a buddy call me in a panic today, his 06 wrx limited failed a smog test on his way to sell the car because of misfire codes on all cylinders. I told him to come over and I'd help him out.
    Car has 92k miles on it and he paid a Subaru dealer to do the 90k service. Read the first page of this thread; cleaned his MAF, checked the plug gap and they ranged from .042-.045. I think the dealer either didn't gap them or put in the NA plugs. I regapd and reinstalled the plugs and cleared the codes. Alternator belt was in horrid condition, so I replaced that too.
    He drove it 80 miles and all the readiness monitors had cleared. Problem solved.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  7. #80
    Jan 2013
    Donkey, thanks for the info. Hopefully I'll be able figure out my cause...
  8. #81
    Jan 2013
    I have 2009 sti is got a misfire on idle but no power loss still drives like normal just abit hard to take off anyone had this problem or can give some advise
  9. #82
    Jan 2013
    No power loss still drives like normal
  10. #83
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Guys and gals, Donkey clearly stated that the purpose of this post is informative only and not intended to become a question and answer session. If you have a misfire code, please read the first post in entirety. If the action points do not resolve your issue, please post a thread explaining your issue. We will do our best to help you on your way. Thread closed to preserve its sanctity.
    If you have a resolution to the misfire, as Donkey suggested, and it's not listed in the initial post or any subsequent posts, feel free to PM me and I will edit this thread.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  11. #84
    zax
    zax is online now
    Nov 2008
    Graciously submitted by user rbblrsn:
    Quote Originally Posted by rbblrsn
    Car: 2006 WRX Limited Wagon, 115K miles, stage 2 Cobb, Greddy 3" exhaust.
    Condition: Car suddenly developed severe stumbling, misfire codes rotating thru cylinders.
    Action: Started troubleshooting per Donkey's post, MAF cleaned, plugs replaced, etc. Found my problem during fuel filter replacement:
    The plastic 1/2 of the twist-together filter canister in the in-tank filter had partially separated from the metal 1/2, and the O-ring was also damaged. Fuel leaked from the resulting gap upon pulling assembly, so I'm sure air could be sucked in also when tank was low or during sloshing from spirited driving. Replaced filter and o-ring, cleared codes and all seems well. There were no obvious signs that it had ever been serviced (lots of dirt on top of the tank) so this may have been a factory issue(??)
    My suggestion for a Possible post update: "Check in-tank fuel filter canister for proper assembly and o-ring integrity to ensure fuel pickup is OK."
    Facebook me here
  12. #85
    Jan 2015
    Cylinder3 Misfire
    ok guys I have a real head scratcher here.
    2008 Impreza 2.5i
    Misfiring in 3
    changed out spark plugs and wire
    new coil pack
    cleaned MAF
    Cleaned Injectors and Flopped 1 to 3
    Here is how the car acts:
    when idling car runs smooth as butter
    under load car wont really accl.
    I can even smash the gas and rpms wont go up fast like they should and when the rpm's finally do reach to about 4,000 the car wont go any higher
    the car is basically undrivable any input would be great appreciated, thank you all for your help
    note I will be doing a compression test in the morning
  13. #86
    Da boonies,Va
    And you read what part of this thread? Did you even read the very first page?
    2002 FORESTER S
    1998 FORESTER S
  14. #87
    Mar 2015
    My 03 wrx runs great with no problem but my check engine is still on and the code say all 4 cylinder is misfiring.and when i pound my car the check engine blink 3 times but still runs normal.
  15. #88
    Da boonies,Va
    Quote Originally Posted by rroberrt94 View Post
    And what part of the first post did you read? Specifically the big letters in red..........
    2002 FORESTER S
    1998 FORESTER S
  16. #89
    Apr 2015
    Thank you this is the most helpful post I've read... I have a 02 that is misfiring on all cylinders but now I have info to try to figure out the problem myself. thanks donkey
  17. #90
    Oct 2015
    sounds like my issue, here are some logs.... https://drive.google.com/open?id=0B_...XQ3Vy1ETW9Bemc
