IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!! - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 94
This is a discussion on IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; OK, so after a long hard drive to campus and after class I turned the car on it looks like ...
    Jun 2010
    New Jersey
    OK, so after a long hard drive to campus and after class I turned the car on it looks like the CEL turned off on its own. I'm guessing that is a good thing, but as I put in the diagnosis computer the code (P0304)was still there except for the CEL.
    What does this mean? and does it come off after a few more miles?
    Thanks in advance.
    Pic to soon to come ...... 19 yrs old. Drive a Subbie( Im a newbie). 3rd Year Of college going to third.
    Aug 2009
    Athens, Ohio
    grounding turned out to be the issue
    I was having problems with my 02 WRX and cyl 3 misfiring. After replacing the spark plugs and running injector cleaner through the system a few times with no positive results, I was about to drop hundreds on new coil packs when I noticed a post about the engine grounding. $5.00 and 1 hour later I had installed a #6 ground wire, which grounded the engine in about 5 additional places. And SNAP!!! the car immediately was running noticeably smoother and I haven't had any other problems with the cylinder misfire. I urge anyone having the Cyl Misfire problem to try this inexpensive, simple modification.
    Registered User jorge02wrx's Avatar
    Apr 2001
    San Diego, CA
    Ash,
    From where to where did you install the ground wire? Is it possible to post a pic of the new wire for better reference? Thanks.
    Jorge F.
    Auto Concept Elite
  6. #19
    Jun 2010
    New Jersey
    Quote Originally Posted by Ash02WRX View Post
    yeah same here. ... any pics
  7. #20
    Apr 2009
    Denver, CO
    Just to reiterate. I've worked on lots of cars old and new and weird things happen. Example:
    I have a 2004 wrx all stock except for the resonator box was removed. Sounds kinda nice
    I was driving and the CEL came on. Ran the code P0301 cylinder 1 misfire. I started with the plugs and all of them were fine. I replaced them anyway because it was cheap. Then I switched the coil packs from 1 to 3. Nothing changed. Still pulled the same code. Then I checked the wires. All were fine. Then I ran a fuel injector through 2 tanks of premium gas. Finally my buddy said to pull the MAF plug while it idles and see if it improves. Guess what...
    So I cleaned off the MAF and it runs fine. Just because it says P0301 doesn't necessarily mean that's the issue. That's just the first place the computer detected a problem so I had to go "further upstream."
    Sometimes I wonder why I even bother lifting up the hood but there's always something new to learn.
    Anyway, don't get tunnel vision like I did and if you submit something to the forum, give as much info as possible because it wasn't until I stopped thinking about the plugs (which were totally clean anyway) and considered that only the idle was rough. I never experienced a loss of power. Be thorough and provide details. Cheers
  8. #21
    Registered User bn_bnntt's Avatar
    Dec 2010
    My 02 Wagon is wigging out. It's got the cobb access port, turbo back exhaust, sti up-pipe. Bought it from a good home with all proper maintenance records. It ran great for a month after I bought it. I recently put new headlight bulbs in it. Had to disconnect the battery and the stock intake tube that opens above the radiator. Afew days after it started to misfire. Running terribly rich with misfire codes/CEL. Replaced the o2 sensor. CEL went away. Ran great on the test drive but started misfiring again on the way back to the shop. Checked records, the fuel injection hose was replaced in 07 (because of the fuel smell in the cold), as well as spark plugs and fuel filter. In 08 the MAF was cleaned. Is it due for a cleaning again already?? I'm going to check all of my ground wires and make sure the intake piece is sealed properly. Though I thought I put everything back in place after the bulb switch. I'm going to run down the checklist on this thread, but does anybody have any thoughts? I'm scared.
    edit- it's not reading any codes but there's white smoke coming from engine compartment??
  9. #22
    Jan 2011
    Missouri
    I had a 2006 WRX TR that I was getting misfires on all four cylinders. The dealer said it was because I installed a K&N air filter and it snapped the tabs holding the air box together causing a vacuum leak. Evidently the K&N's are too tight a fit for the airbox. Just thought it's another thing you could check.
  10. #23
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Ol' Lightnin' View Post
    Considering there's no vacuum plumbing before the MAF, I don't see how that could haver caused a vacuum leak...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  11. #24
    Jan 2011
    Missouri
    They said it was getting to much air and the engine was over compensating causing the misfire. Sometimes I wonder if the dealers even know what their talking about. My car got totaled before I was able to resolve the problem.
  12. #25
    Feb 2011
    Longview, Alberta, Canada
    My 02 ran great but then my CEL came on and registered 2 misfires. It still ran just fine but I thought I would change the plugs anyway. After changing all the plugs, I took it for a test drive. As soon as I gave it full throttle, the CEL came back on and the car would start jerking as if I was repeatedly pressing and depressing the throttle. I didn't use the plugs you stated before, but could that affect the power output that much?
  13. #26
    Moderator Donkey's Avatar
    Da boonies,Va
    Yes. If the plug gap is wrong,the coil pack not seated properly or the harness for the coil packs were switched. What plug exactly did you use?
    2002 FORESTER S
    1998 FORESTER S
  14. #27
    Feb 2011
    I used NGK plugs, but they weren't iridium. Could that cause a power loss? I just used what Canadian Tire refered me which was not a smart decision in hindsight. I'm going to run through your check list as soon as I can also.
  15. #28
    Feb 2011
    Cleaned the MAF and runs like a champ again. I'm still getting a misfire but i'm much happier now. I think I just need to get the iridium plugs and actually gap them to specs. Thanks a billion.
  16. #29
    Mar 2011
    how do you use BG Chemtool n Gm top end cleaner? and how do you check the valve clearence?
  17. #30
    Oct 2010
    OK my stock 04' WRX 145k miles has a P0304, and after buying the spark plugs, coil packs,cleaning MAF, and one bottle of injector cleaner still code. So a month later(today) I did a compression test......
    Engine was Cold, results were: 150,150, 151, 149
    Is this a good thing?? and if so what should I do next by the injectors or 02 sensor.
