Results 1 to 11 of 11
This is a discussion on P0304 code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I got a P0304 Code on a couple of days ago. I've replace all 4 plugs and the #4 cylinder ...
    Oct 2010
    Lowell, MA
    P0304 code
    I got a P0304 Code on a couple of days ago. I've replace all 4 plugs and the #4 cylinder coil pack and cleared the code.
    1 day later the car is still misfiring and the same code pop up again.
    Should I replace all 4 coil pack?
    No.
    How did the spark plug look from no.4?
    Check the clips and little wire thingies.
    Oct 2010
    Lowell, MA
    The # 4 plug look normal just like the other 3 plugs, I don't get it. No oil or sign of it being lean. Maybe the # 4 injector is clog?
    It is possible but not as common as a wiring fault or a coil fault, and you have excluded the latter. Is the car stock? Are there mods that would make it likely the code is legitimate (power mods etc.)?
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Oct 2010
    Lowell, MA
    Car is completely stock. It has 196K miles I've did use injector cleaner. # 4 coil has been replace as well as all 4 plugs. I will double check the wiring.
    Oct 2010
    Lowell, MA
    Thanks for the link, I will do the following.
    Oct 2010
    Lowell, MA
    I've just replaced the PVC valve, cleaned the MAF sensor with CRC MAF cleaner and I've also cleaned all 4 of the coil pack plugs. I will pour in a bottle of Sea Foam in the fuel tank and see what will happen next.
    As of now it is still not a smooth.
    Oct 2010
    Lowell, MA
    I got the same code again today P0304 it is ticking me off. I'm starting to dislike Subaru.
    Registered User fortunesk89's Avatar
    kenosha wi
    fuel grade? how fast does it recode? try to ohm the injectors or swap with a different cylinders injector
    2002 plat. silver wrx
    Oct 2010
    Lowell, MA
    I only use premium grade fuel. It recode about every 100 miles. I'm thinking about replacing the # 4 injector. I'll try new inject cleaner for a few more tanks to see how it does. If not I'll replace 1 injector.
