P0420, only in the rain
Results 1 to 3 of 3
This is a discussion on P0420, only in the rain within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, my car's been through a few entire I/M readiness cycles, and just twice the CEL has come on with ...
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    So, my car's been through a few entire I/M readiness cycles, and just twice the CEL has come on with P0420. Both times it's been on a highway in the rain. I'm seriously thinking that the problem is not a cat problem, but an O2 sensor problem.
    I'd like some other opinions, though. What would cause an apparently good exhaust to say that there are cat efficiency problems in the rain?
    I took a look at the sensor itself (didn't take it out), and the wire seems loose but not broken I don't think... not sure how to tell if it's bad without replacing.
    Anything I can check, datalog, take pictures of, etc. to diagnose this problem? I'm probably going to do the mechanical CEL fix later on when I go nearly or totally catless, but I'd like to make sure that there's not a problem with the sensor or its wiring...
    Any ideas appreciated.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Moderator Donkey's Avatar
    Da boonies,Va
    Could just be an exposed connection at the wire. Maybe try using some liquid electrical tape or something where the wires go into the sensor.
    2002 FORESTER S
    1998 FORESTER S
    Check the connection on both ends and the wire again. This is tough because you're not going to be able to fix something that works. I agree with Donkey.
