04 wrx idles high on cold start
Results 1 to 6 of 6
This is a discussion on 04 wrx idles high on cold start within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, After a timing belt change i have a few problems (one listed in another thread) but another problem i ...
    Mar 2009
    Hello,
    After a timing belt change i have a few problems (one listed in another thread) but another problem i noticed is that my car will idle at around 1500-rpm on a cold start. After letting it run for about 2-5 minutes it will settle down and idle at 700-900rpm (which is what it was at prior) I dont have any electrical items on (radio, lights, etc) and the a/c and heater are also off. Any ideas?
    Thanks
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by bschr287 View Post
    Hello,
    Thanks
    Cold idle is higher than warm idle, If you give it a shot of the throttle does it bring it down a little bit once it settles back at idle?
    Registered User BigB007's Avatar
    Mar 2007
    PA
    Hello,
    Thanks
    I'm pretty sure that is normal.......
    Bugeye Mafia #141 Military Militia #007 Hawkeye Alliance #126 The Stink-Eye Mob #92
    03 WRB WRX - Sold
    07 WRB STi - Sold
    11 SWP WRX - Current
    Feb 2010
    SL,UT
    Its normal... cold winters here in utah cause my rex to idle about 1500 rpm's and after it warms up it goes down to about 600 rpm's... if it is up that high you can jab the gas a little bit and it will go down... I'm pretty sure its just to warm up the engine faster when cold...
    Hawk-Eye Alliance #801
    Mar 2009
    thanks guys,
    the dealer said it is normal and i just wanted to double check.
    Aug 2010
    High RPM on start could be sign of rear cat converter failed weld
    My 2004 wrx had a failed weld on the rear cat converter. This showed up as high RPM on startup and slightly more engine noise in the cabin. Not noticeable at first but got progressively worse. If under 8 yr/80000 miles it is a warranty repair so I got it fixed for free.
    If real cold like one gets in Minnesota, then 1500 rpm is normal. I started seeing these 1500 rpm levels in 50 to 70 degree weather so I knew something was wrong.
    If you have access to a lift, take a flashlight and inspect the entire exhaust system otherwise you can just wait and see if it gets worse.
