Page 1 of 3 123 LastLast
Results 1 to 15 of 32
This is a discussion on Are Turbos Supposed To Squeal When Cold?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I started up my WRX this morning, it was sitting outside and it was a bit cold. When I was ...
    Registered User glamoureux's Avatar
    Oct 2010
    I started up my WRX this morning, it was sitting outside and it was a bit cold. When I was driving down the road I used the turbo, and it made this high pitched squealing noise that I have never heard before. After a little while of driving it subsided. Is it supposed to do that when its cold?
    I just want to make sure its not broken.
    No.
    It's not necessarily the turbo. It could be a belt. What year car? What mods? What miles?
    Oct 2010
    its a 2002 wrx with 60,000 miles, an STI turbo, blow off valve, and stage 2 reprogrammable computer
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    It possibly sounds like a small pre-turbo exhaust leak. They will screech during boost when the pipes are cold, then quiet up when everything heats up and expands.
    Oct 2010
    So what does this mean? Is it a bad problem?
    May 2003
    Quote Originally Posted by glamoureux View Post
    Not horrible, but it should be corrected if that's the problem. If that's the problem, the gasket is cheap. It's just labor that could be a few bucks if you can't do it yourself.
    Oct 2010
    what could have caused this to happen, because i didnt even push it hard.
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    gaskets wear over time, they are usually made of some sort of rubber compound. heat and cold will make them brittle and they will break and leak.
    even though you only have 60k and never drive your wrx hard, the car has been on the road for 8+ years, and over that time, the gaskets will wear and need replacement.
    its nothing huge to worry about, just maintenence and wear and tear
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
    Oct 2010
    ya that could be it. i just dont want the turbo to be broken. im new to turbos
    Dec 2003
    Dallas, TX / Sterling, VA
    What are the rest of the mods?
    Oct 2010
    an exhaust and thats about it
    Dec 2003
    If literally all you have is what you listed, this car shouldn't be being driven.
    Jul 2004
    Seattle, WA
    Quote Originally Posted by brfatal View Post
    If literally all you have is what you listed, this car should be being driven.
    +1
    It's well documented that in order to upgrade a turbo a WRX requires several things.
    Turbo
    Fuel Pump (Walbro 255)
    Larger injectors (565cc would be ok for a VF39)
    Uppipe/downpipe (uppipe only required on 02-05 WRX's)
    An OTS map for that turbo/injector set or a custom tune.
    Oct 2010
    why?
    Oct 2010
    it has the top mount intercooler, the up pipe, the down pipe, injectors, STI turbo, STI struts, Exhaust, Blow off valve
