This is a discussion on PS Problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just got a new power steering pump and threw it on. As soon as I start the car and ...
I just got a new power steering pump and threw it on. As soon as I start the car and turn the wheel the pump whines like crazy. Is it a bad pump or is there air in the lines.
I tried the bleed the system for about ten minutes and drove around for about 10 min and the whining didnt go away and the power steering seemed to get worse and started to go in and out.
Any help is appreciated.
07 WRX STi Stock - my new baby
02 WRX 225 hp 222 tq - Not at Fault Accident TOTALED
If there was an air bubble in the rack would it cause the pump to whine? And the whine only occurs when the pump is under a load like when I turn the wheel or hold the wheel all the way to the right or left. Also if i rev the motor when turning the wheel the whine gets super loud.
I already swapped my old one back in that doesnt work at all becuase I thought the new one was junk so i was gonna return it. The old one doesn't make any sounds but also doesnt have any power steering but it does flow a little because i can see some fluid get pumped into the tank every 2 seconds.
Would it be worth it to try the new pump again and see if it gets better?
did you buy a rebuilt, used, or brand new? would like to know how it turned out since I am looking to replace mine soon since it now whines when its could and goes in and out through my 6 mile drive to and from work everyday....
