Results 1 to 6 of 6
This is a discussion on Quick issue, need to know if I'm correct. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well, earlier today as I was going to class, I had eerie feeling that a code probably turned up. So ...
    Jun 2010
    New Jersey
    Well, earlier today as I was going to class, I had eerie feeling that a code probably turned up. So before going to class I connected my comp in and what do you know code: P0171, I believe it said running lean, I just want to know if this is cause of my turbo hose which is damaged and I planned on replacing it on sunday myself (I had a new replacement piece for a week now, but never had the chance).
    ** The CEL was and is not currently on, thankfully.
    Thanks all in advance, seriously thanks
    Pic to soon to come ...... 19 yrs old. Drive a Subbie( Im a newbie). 3rd Year Of college going to third.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    maybe this will help:
    http://forums.nasioc.com/forums/showthread.php?t=475620
    i dont know what year you have but this is for an 02/03
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Jun 2010
    New Jersey
    well, its an 04 WRX, don't know if that helps. To tell you the truth I always heard a whistle sound( whhissssh!!! ) everytime over 2.5 or 3 rpms, I never knew that was a bad thing, FML.
    A boost or vacuum leak can cause a PO171, yes. So can a dirty MAF sensor, a dirty air filter, an unseated air filter cover, an incorrect intake, a loose connection to the FPR, and so on. A BOV counts as a leak too.
    Jun 2010
    New Jersey
    well, I guess is the turbo hose, today I went to take a quick look at it, and there is a nickel size tear into the hose.
    zax
    zax is offline
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by nunez07c View Post
    Please define "turbo hose." I assume you are referring to the wastegate actutator plumbing, which I don't see as a cause for your problem. Though, I tear may cause a vacuum leak in the system, which could cause a CEL. Pics will help.
    Facebook me here
