need help please
Results 1 to 15 of 21
This is a discussion on need help please within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello to all,i have just got a wrx and its pissing out oil out of the blow off valve can ...
    Registered User paul golden's Avatar
    Oct 2010
    need help please
    hello to all,i have just got a wrx and its pissing out oil out of the blow off valve can any one help me in any way,i was told i need a new engine:)
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by paul golden View Post
    Why did you buy it like that? That's my question.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Apr 2007
    8000' up in Colorado
    Wow that is not a good problem. Somehow oil is getting into the airflow. I'd check the turbo first and then move on to the engine. Don't drive it like that, you might get away with only having to replace the turbo and not the engine. But keep driving it and something is going to go.
    Scott
    Jul 2010
    Cincinnati
    How much oil are we talking here? and where on the BPV is it coming out? Could be a simple fix
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    it sounds like either a blown turbo seal or excessive blow-by. Either way, not good.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2009
    Canada/Ethiopia/Madagascar
    If it's a turbo seal there's a high likelihood you'll have oil on the hot side, i.e. remove the down pipe to check. Will be hard to tell by a quick inspection if it's purely blow by since your intake tract is full of oil if it's puking out your recirc valve.
    Ensure your oil level stays topped up, religiously, although I'd advise against driving the car. Low oil can lead to a whole other can of worms.
    After a drive, and removing the oil cap, do you see any smoke come out?
    Get a compression and leak down test done. If purchased from a dealership do it on their dime.
    ...Rob.
    Palmyra, NJ
    Quote Originally Posted by Drews View Post
    +1
    But everyone else has good advice, so I advise you to listen...Subscribed to find out details. Goodluck!
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by mudferret View Post
    Yeah I agree. You would see a lot of white smoke from oil contacting the exhaust gases as well.
    Facebook me here
    Aug 2009
    Another thought, remove the valve, to check the seal out, quantity of oil; we know your seal is probably damaged since oil is getting past it; not sure if a boost leak at the flange + a little bit of oil could make it seem worse than it is. A poster above mentioning that it could be a simple issue made me think of this. Some people do get a little oil in their IC's; so in some cases it's "normal".
    ...Rob.
    Oct 2010
    subaru wrx
    yes i bought the car yesterday and was told that one of the piston rings were ****ed,the car starts and drives,low on power and theres a lot of oil comeing out the blow off valve,i was told a new engine would be the best thing to do,i am in no real hurry to fix so i will like to find out first could there be anything done.
    Dec 2003
    Dallas, TX / Sterling, VA
    Time for a compression test.
    Oct 2010
    subaru wrx
    ya that wat ill get done thans.
    Oct 2010
    subaru
    well had a look today at subaru and i have sourced were the oil is comeing out,i thought at first it was comeing out the dump valve but its not,its comeing out a little pipe on the left side of the car near the spark plugs wat would dis mean fellas.
    Registered User STTI's Avatar
    Sep 2010
    Auburn, GA
    Driver side or passenger side? pic would deff help
    I know I got oil in my IC, I need a Oil catch can.
    "STTI" Is for Subaru Twin Turbo Impreza.
    Since My EJ20R says 2 stage twin turbo, does that mean I am already at stage 2?
    zax
    zax is offline
    Nov 2008
    Sounds like the passenger cylinder head vent. You are getting lots of blow-by in the intake from this. An AOS or catch can will reduce the amount of oil blown back into the intake, but you're avoiding the problem. Without a doubt, you have a blown piston ring. Get a compression test done. I guarantee you will have low compression in one of passenger-side cylinders. Time for a rebuild (might as well while you're in there)!
    Facebook me here
