Results 1 to 7 of 7
This is a discussion on coolant leak???? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I popped my hood a while back and saw greenish white splatters around the radiator belts and hoses thought nothing ...
    Registered User Bblue Rrex's Avatar
    Aug 2010
    Pennsylvania...woo
    Question coolant leak????
    I popped my hood a while back and saw greenish white splatters around the radiator belts and hoses thought nothing of it and just cleaned my underhood. Now I popped my hood again and saw the same thing. It looks as if there's a tiny leak somewhere and its hitting the blets and fans and spraying it around. My coolant levels are still around full and I'm not leaving behind any puddles under my car....
    Any help? I would just like some ideas of what it may be and what to check.
    Thanks guys
    2002 WRB WRX
    Bugeye Mafia #335
    High Mileage Club 106K
    My Pics
    Oct 2005
    Late Devonian
    If you can't find where it is leaking from with the car running then you need to get a pressure test. Watch out for the fans etc. You don't want it to all of a sudden get worse and leave you stranded.
    Nov 2009
    If your radiator is stock I bet it cracked. Rev it while you look at the radiator I bet you will find the leak.
    Jul 2010
    Cincinnati
    Buy a cooling system pressure tester, it's a super valuable tool and will help you find your problem. You can find them fairly inexpensive, I think they even sell them at autozone and pep boys.
    Registered User 04WRXR's Avatar
    Mar 2006
    Fredericksburg. VA
    Is the radiator cracking a regular problem for the rex's? I'm just had the same problem with my 04. The coolant shows up everywhere on the engine bay and when the fans kick on you can REALLY smell it.
    04 WRX wagon
    Cobb Stage 1 93
    Waiting to be installed: Godspeed bellmouth DP
    Photography Portfolio: www.180Reflections.com
    Jul 2010
    Cincinnati
    Quote Originally Posted by 04WRXR View Post
    It's a regular problem with any plastic tank radiators, Not really a Subaru specific issue.
    Mar 2006
    Fredericksburg. VA
    Plastic tank radiators? It's the radiator aluminum?
    04 WRX wagon
    Cobb Stage 1 93
