750 RPM seems right for the 2.0L. After a cold start, the idle is around 1500 RPM, settling down to 750 RPM when warm.
This is a discussion on what does a typical WRX idle at? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Soo the past week my car has been idling around 750. For the past 4 years it has been idling ...
Soo the past week my car has been idling around 750. For the past 4 years it has been idling at around 1000. The car sounds a bit different too. When i give the car gas it seems to run fine though....any ideas?
05 WRX WOOT
Facebook me here
Originally Posted by Mikie13
750 is correct, 800 when the a/c is on.
...or, if it's my car, 700 is where it sits...
May I jack this thread to ask what I can do to fix that?
My big thread: The Used WRX Buying Checklist - Please Contribute!
My current car: 2002 WRB WRX Wagon.
Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
If you both have an issue with the idle changing (i.e. sometimes idling at 1000 RPM and other times idling at 750 RPM) when the engine is warm, I would check the IAC valve integrity. Although usually an IAC fault causes the engine to stall or rough idle...
Facebook me here
I got the throttle body and the throttle body plate cleaned. It had carbon build up in it. I figured it would fix the problem but it really didnt. My engine just sounds really putty right now...which is lame when im sitting in traffic. I still dont udnerstand though why it would change idle after 4 years though.
05 WRX WOOT
Facebook me here
Maybe i should just face the fact that my car is getting old. 93k miles on the old girl. I should just give her a nice buff before the winter time and cheer her up.
05 WRX WOOT
mine idles around 750
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
From: http://www.cars101.com/subaru/impreza/wrxsti2007.html
2002 - 2004
Couldn't find data at link above
2005 WRX
idle rpm at park- 750 +/- 100
2005 STI
idle rpm at park: 700 +/- 100
2006 WRX and STI
2007 WRX and STI
02-04 wrx is 750.
The way to check is to pull your rom - the idle control things dictate where idle should be...
...what makes idle be low? what should I check?
I would be more concerned about why the car idled at 1000 RPM for 4 years without changing the IDLE RPM parameter
Facebook me here
how could i possibly look at it wrong? Its almost impossible to confuse 1000 with 750. It just changed one day...or maybe i'm just going crazy. In any case....I will pull the IAC on my next day off and clean it. If it doesnt fix the problem....then its probably not worth it.
05 WRX WOOT
