Gas peddle response 2008 wrx sedan
Results 1 to 9 of 9
This is a discussion on Gas peddle response 2008 wrx sedan within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Question about my 2008 wrx sedan. Lately I have been noticing that I have not been getting as much 'response' ...
    May 2009
    Colorado
    Question about my 2008 wrx sedan. Lately I have been noticing that I have not been getting as much 'response' out of my gas peddle. It's really hard to tell if it's always been like this or if it's getting worse, etc... I practically have to push it half way down to get anything at all. This is especially annoying when i'm 1 trying to get smoothly into first, 2 shifting from gear to gear and 3 trying to slowly and carefully back out of a parking spot in a crowded parking lot. I wish I could get more rpm's with less pressure on the peddle... any ideas? THANKS
    Registered User REXme's Avatar
    Apr 2009
    Buffalo Grove
    Quote Originally Posted by jakemk7 View Post
    You could start my checking the tension in the throttle cable.
    Jul 2004
    Seattle, WA
    Quote Originally Posted by REXme View Post
    06+ WRX's do not have throttle cables.
    1. Getting smoothly in to first requires 1a. from a stop, more slipping of the clutch. 1b. while moving, revving the engine more for it to fall in to place.
    2. Again revving the engine a bit more for it to fall in to place.
    3. The 5-speed transmission doesn't like slowly starting.
    It's always done this, you're just becoming more aware of it.
    You have a choice here: smoother transitions or longer clutch life.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by SeattleJeremy View Post
    This. The 06+ use drive-by-wire, which begs the question, have you recently changed any throttle map settings perchance?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    May 2009
    Colorado
    Thanks for the help
    Thanks everybody! I would choose longer clutch life over smoother transitions just because I would rather have less smooth shifting but not have to spend $1500 + on a new clutch before I even reach 60k miles. I recently installed a cold air intake but I would doubt this has anything to do with it right??? FYI yes I do know a CAI is a bad first mod but I found that out after I put it on so next sunny day off I get it's coming off until I get a new exhaust and chip upgrade. Would anybody say it's "BAD" in a way to always be super reving the engine to get into first or can the wrx's engine take it? Thanks again!
    Moderator Donkey's Avatar
    Da boonies,Va
    Uhh...you shouldn't be having to rev the engine to get it into first gear. And you should never force a transmission into gear. If you talking about down shifting into first I highly do not recommend it for any speed over say 5-10 mph. If the throttle just seems laggy,then get some engine management. First thing they do is massage the Drive By Wire throttle tables.
    2002 FORESTER S
    1998 FORESTER S
    May 2009
    Colorado
    Blitz throttle control
    Does anybody know about this Blitz brand throttle control module that supposedly increases sensitivity of the throttle peddle? Is it good or bad? Does it work or is it just a gimmick. I imagine for $350 it's probably the real deal... Anyways it sounds like exactly what I need. Any thoughts? Thanks
    zax
    zax is offline
    Nov 2008
    Dude, Donkey is right. You need to purchase some form of engine management. Not only will it adjust your throttle map parameters allowing for crisper throttle response, it will also allow you to tune your engine.
    Facebook me here
    Da boonies,Va
    Its crap. Put that money towards EM.
    2002 FORESTER S
    1998 FORESTER S
