Results 1 to 2 of 2
This is a discussion on A/C PROBLEM within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok, so everyone in a while, my A/C will just start blowing cool air. I have to wait about a ...
    Registered User traumawrx's Avatar
    Oct 2007
    A/C PROBLEM
    Ok, so everyone in a while, my A/C will just start blowing cool air. I have to wait about a minute and turn off the A/C in the car and then turn it back on and then the cold air starts up again. There is no a/c clutch clicking on an off during this too. Do I just need refrigerant or what? any ideas, thanks!
    The only way to tell if you need refrigerant is to measure the pressures generated.
    Your symptoms could also be a thermostat or an expansion valve. The former seems more reasonable but the latter is more common on these cars.
