white smoke from exhaust on start up - Page 2
Results 16 to 30 of 32
This is a discussion on white smoke from exhaust on start up within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Based on your oil light flickering recently, yet there still being an appropriate amount of oil in the engine, it's ...
    Aug 2009
    Canada/Ethiopia/Madagascar
    Based on your oil light flickering recently, yet there still being an appropriate amount of oil in the engine, it's possible that you have a broken oil pick up tube or a bad pump, which leads to oil starvation.
    ...Rob.
    Administrator
    May 2003
    Quote Originally Posted by jmb8806 View Post
    not that it matters at this point but out of curiosity what causes this to happen because its not like i didnt take care of my car....?
    How often did you change the oil?
    How much oil was in the car when the oil light came on, before you changed it?
    Registered User jmb8806's Avatar
    Apr 2007
    Exton, Pennsylvania, United States
    i used synthetic and i changed it every 4-500 miles... the oil never was low when the light came on.
  6. #19
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    you changed the oil ever 4-5 hundred miles? Im assuming you meant 4-5000 miles? Subaru calls for 3000 even if your using extended life oil.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  7. #20
    Apr 2007
    my set up is spt intake, hks catless downpipe, and spt exhaust, tuned to stage II with a cobb ap. does anyone think that this contributed to my problem. the only thing i can think is that i ran it for about 6 months without the AP after i did the downpipe, which caused y car to over boost pretty bad....thats the only thing that i can really think off...
  8. #21
    Aug 2009
    There's a distinct possibility that's exactly what caused it.
    ...Rob.
  9. #22
    Apr 2007
    im just trying to avoid this happening again. i did get the over boosting fixed, but im thinking of putting my stock catted DP back on to be on the safe side. the new rebuilt motor, plus all 100k maintenance is going to run me from 6-8k so i want to make sure that i get the most out of the car.
  10. #23
    Aug 2009
    I wouldn't be afraid to run a DP on your new engine, you just have to be tuned for it from the get go. Skip the Cobb map altogether and get a custom one made for you car.
    Good luck.
    ...Rob.
  11. #24
    Dec 2003
    Dallas, TX / Sterling, VA
    Overboosting is only part of the problem. You were also running VERY lean every time you ran into boost.
  12. #25
    Registered User scooby uk's Avatar
    Sep 2010
    england
    you shouldnt have left it till the oil light came on cuz you left it till the light came on it could have already caused alot of harm to ya engine i check mine once a week!!good oil and filter are important to ya scooby its not cuz ya got to much oil in cuz the smoke would be blue not sure what it could be but white smoke is not good!!i would sell it and get a better scooby or you could spend loadz on fixing it
  13. #26
    Apr 2007
    well how would i fix the problem of running too lean?
  14. #27
    Dec 2003
    Problem already solved, you got tuned. Removing the cats drops the post-turbo exhaust restriction significantly. This increases the pressure drop across the turbo, which spools it quicker. Because it's easier to spool the turbo, the turbo spools sooner (lower RPM). This means the stock delay the ECU uses before it switches to open loop fueling is now too large, which means the car will continue to stay in closed loop (14.7 AFR) well into boost, which can cause detonation/damage.
  15. #28
    Moderator Donkey's Avatar
    Da boonies,Va
    You really need to research more before modding your car. And when lights on your dashboard come on thats a sign you need to figure out whats going on before driving it anymore. My suggestion would be to buy an oil pressure gauge.
    2002 FORESTER S
    1998 FORESTER S
  16. #29
    Apr 2007
    just out of curiosity what do you guys think i could get for my car as is....this is what i got
    2006 wrx tr stage II
    87k
    spt exhaust
    hks cattless DP
    spt intake
    b&M short throw shifter
    Kenwood touch screen nav
    cobb ap
    spt strut tower brace
    all heat shields
    dba slotted rotors
    needs new tires
    needs either new motor swap or a rebuild.
    as of now it runs but the bottom end is pretty much shot
  17. #30
    Dec 2003
    Car without an engine is pretty worthless. I was offered $4k for my car with about $25k in mods in it when the car needed an engine rebuild.
