Changing Spark Plugs Today!!!
Results 1 to 15 of 19
This is a discussion on Changing Spark Plugs Today!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Alrighty! With some know how that ive gained from this forum ill be finally attempting to change my spark plugs. ...
    Registered User WRX-KING's Avatar
    Sep 2010
    408, CALI
    Alrighty! With some know how that ive gained from this forum ill be finally attempting to change my spark plugs. was kinda nervous of breaking something at first but after watching some informative youtube clips and with help from CLUBWRX posts im pretty confindent at this point! wish me luck guys!!! lol
    oh and any recommendations on plugs for a stock 02 bugeye?
    Registered User McGizzle's Avatar
    Nov 2007
    Toledo, OH
    I changed my stock '04 plugs a few months ago and stuck with the stock NGK iridiums from the dealership. Also, I'm not the most mechanically inclined individual, and I had no problems swapping them out.
    ....oh and.....good luck!
    I.Y.A.A.Y.A.S.
    Blobeye Syndicate #311
    Sep 2010
    408, CALI
    Quote Originally Posted by McGizzle View Post
    sweet! may try the stick with the stockies too!
    The stock plugs are platinum. There are corresponding iridium part numbers I believe.
    Sep 2010
    408, CALI
    okay....so....spark plugs changed....new fuel filter and fuel system cleaner. one problem....reason i was actually wanting to do all these maintenance items is that my car doesnt some to want to make power on the top end. at about 4000-6000rpm it struggles to want to do anything. if i continue to punch it forcing it to redline my CEL blinks like crazy. (most likely misfire) so naturally i wanted to change the plugs, inspect the coils, clean the fuel system but not a change at all. same problem. has great power up until 4500rpm....and my i add im only getting a maximum 9psi boost according to my boost gauge. please if anybody has any idea of what may be causing this please let me know, as this is starting to get frustrating....thanks in advance.
    Nov 2007
    Toledo, OH
    doh!!...that is correct sir. I went with these from subaruparts.com:
    BKR6EIX11 Ngk Iridium Ix Plug
    I.Y.A.A.Y.A.S.
    Quote Originally Posted by WRX-KING View Post
    Post the CEL code number and a list of all mods.
    Sep 2010
    408, CALI
    P0301
    P0303
    P0304
    Zero mods from what i can see in the engine bay....bought the car used. i know it used to have an exhuast (no to sure if it was a full cat back or anything) but was reverted back to stock when i bought it. i know that those are misfire codes but they NEVER show up unless i really try and push the car passed 4500RPMS....if i keep it below. no problems.
    May 2010
    Pittsburgh, PA
    Has it been tuned at all?
    Sent from my Droid using Tapatalk
    2011 STi Build Log
    Sep 2010
    408, CALI
    well, i dont believe so. ive only owned the car for about two weeks and was wondering what ill have to do next to get it done. sucks, cause i know what a good running wrx feels like after 4500rpms and mine struggles...
    May 2010
    Pittsburgh, PA
    Well I'd wait for somebody with some first hand experience, but you may want to make sure he didn't have it tuned before it was returned to stock. You might be running a tune for a car with 3" exhaust or something.
    ...That is a shot in the dark. Really just a guess. Some datalogging from romraider may give you some clues though.
    2011 STi Build Log
    Jul 2004
    Seattle, WA
    Has it always done this (sense you bough it)?
    Or just sense changing the sparkplugs?
    What sparkplugs did you use?
    Sep 2010
    408, CALI
    Quote Originally Posted by SeattleJeremy View Post
    yes, ever since i bought it. used NGK OEM replacements....same outcome..
    Jul 2004
    Seattle, WA
    Then the spark plugs where not the cause of this problem.
    There are other ways to hit these codes, and this is just a theory.
    The previous owner needed a new clutch, so they purchased an aftermarket clutch and lightened flywheel. Thinking lighter is better, they installed one that was too light. When the car was traded in it retained that light flywheel, causing the ECU to complain (flashing cel) due to the engine revving too quickly.
    Reference thread.
    http://forums.nasioc.com/forums/showthread.php?t=563477
    Sep 2010
    British Columbia
    Nice theory but completely out to lunch on the flywheel bit. a flashing c.e.l. is ALWAYS caused by malfunctions that will allow raw fuel to hit the cat convertors and melt them to ****.... i.e. misfires and such. the rpm/flywheel issue is a non issue as far as i'm concerned, as many people such as myself have excessively lightened flywheels. i would start with the fuel delivery system due to the fact that it only occurs at high rpm, check fuel pressure and replace fuel filter, also a good idea to verify fuel flow as limited flow will also cause this condition. if that all checks out i'd be checking ignition coils/connections.
