no start after motor swap
Results 1 to 6 of 6
This is a discussion on no start after motor swap within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; replaced the small block (due 2 spun rod bearing), water pump, oil pump, and timing belt on an 03 wrx ...
    Aug 2010
    all done by prof. car was completed, wouldnt start. ripped apart, and put back together. still wont start.
    anyone have this problem b4??
    and if so, wat problems were u having and wat did u do to fix it?
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Timing: is it 100% absolutely correct?
    Fuel: do you have fuel to the injectors?
    Spark: do you have spark to the plugs?
    Lead Wrench @ WTF Tuning, LLC
    Jan 2005
    Eh, whaaaaa?
    Also, make sure all of the sensors are checked. Sometimes even one plug left unplugged can cause the car to not start.
    Cody
    Aug 2010
    im sure its timed properly. i do believe he sed somthing about the spark. ummm, replacing a few sensors 2day. will ask about fuel injector.
    thnx
    Aug 2010
    ok, kool. come 2 find out, there was a small (i couldnt see it) nick in my timing gear. bought the new gear. car runs great
    Sep 2010
    British Columbia
    i've seen a lot of people mix up the fuel line and fuel return line which obviously causes a no start, verify that the fuel hose coming from the center of the fuel filter goes to the top of the three connections at the fuel rail
