i have an 02 wrx with cylinder 4 misfire
Results 1 to 4 of 4
This is a discussion on i have an 02 wrx with cylinder 4 misfire within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my 02 is having cyinder 4 misfire, and we checked the coil pack they are good, checked the plugs they ...
    Jul 2010
    my 02 is having cyinder 4 misfire, and we checked the coil pack they are good, checked the plugs they are good, we are thinking that it is the injector. can anyone give me advise with whats going on here
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by cody199 View Post
    How many miles are on the vehicle? If you are 100% sure that the plugs and the coils are good, than I would be checking the joint connectors between the battery and the washer bottle, I have seen terminals back out of these before and cause misfires as well as no starts etc etc etc... Have you done a compression test? Also if you have a set of noid lights available than I would make sure the injector is being fired...
    Jul 2010
    it had a new motor put in it with 72k miles on it but the car itsself has 167k idk when they put the motor in if they used the same injectors or not
    Jul 2010
    it was the injector thanks guys
