my poor suby
Results 1 to 6 of 6
This is a discussion on my poor suby within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so i have a 2003 wrx that i bought with a supposedly bent valve due to installing the timing belt ...
    Sep 2010
    my poor suby
    so i have a 2003 wrx that i bought with a supposedly bent valve due to installing the timing belt out of time after replacing a blown headgasket so i reinstalled the belt to the proper time and ran a compression test to find that 1 cylinder had low compresion so pulled the engine sent the head to the machine shop were they said the valves wer not bent but just not seating put the car back together and still low compresion on that cylinder ahhhh! wat do i do next the car only has 19000 miles
    Aug 2008
    Kennett Square, Pennsylvania
    Did you happen to look at the pistons while you had the head off? Which cylinder has low compression? Did you do a leak down test also? ( this could easily help narrow it down ) ...
    Sep 2010
    it was the drivers side front cylinder the piston looked fine and the head was pressure tested but the car sat for 3 years before i bought it could the rings b stuck from sitting?
    Aug 2008
    Quote Originally Posted by subaro View Post
    hmmm, I suppose its possible however I would do a cylinder leak down test before you just start condemning things...How low is the compression?
    Sep 2010
    I believe that the block was also pressure tested the compresion was 25 psi so we tryed running the engine to c mayb things woud seat n we wer able toget 50 psi P
    Aug 2008
    Either way both of those readings are extremely low...If you have a ring problem it should become evident with a leak down test... pretty much all you are doing is regulating air pressure to enter the combustion chamber while holding the piston at TDC...
