Did you run a car fax on it? That will tell you where it came from.
When my car is idling, the fan constantly turns on/off - even when it isn't that hot outside, and the car runs fine.
Do you have the right coolant in the car? If you have a leak, you need to get that repaired, otherwise you will never be able to keep the proper amount of coolant in.
LinkBack URL
About LinkBacks
