poor fuel milage ?
Results 1 to 15 of 18
This is a discussion on poor fuel milage ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello i just got my subaru running. it runs good but im under the impression that is using way to ...
    Jul 2010
    Hookedonphonex
    Question poor fuel milage ?
    hello i just got my subaru running. it runs good but im under the impression that is using way to much fuel. im trying to figure out what could be the cause. i know one of the sensors on the uppipe is no longer being used. its bypassed with a resistor can that have anything to do with fuel milage. the car has all the mods to run stage 2 but has not been tunned yet. anyone ever dealt with anything like this.
    May 2007
    orlando flawduh
    what are you driving?
    what MPG are you getting?
    desiree
    Jul 2010
    Hookedonphonex
    2002 wrx
    if i would have to guess id say not even 10 to a gallon. im goin to fill er up again and actually keep track.
    i know i put 10 gallons in it gave me 3/4 tank after 24 miles i was below half tank.
    Aug 2010
    Garbage Grove, CA
    Why was the car not running?
    If it was due to Modding - Just get it tuned or reflash it.
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Jul 2010
    Hookedonphonex
    okay thanks everyone. i am looking into getting it tuned. just need to find a good tuner in phx. hopefully that takes care of it.
    the car was not running when i purchased it. well it was running but it was running on 2 cylinders. we pulled the engine and found 2 burnt exhaust valves on pistons 1 and 3. got it all fixed put it all back together car runs good. just tryin to figure out the car and whats all been done. everything on the car is from the previous owner.
    its got full exhaust and uppipe the sensors are still there i know one of them is bypassed with a resistor which i have been reading that seems to be pretty common when modding. as for that i need to get it to pass emissions does anyone know what they look for at the dmv.
    i know in AZ they just hook up to the cars computer and check for the check engine light. which my engine light is not on due to that resistor im sure. so my ? is will it pass emissions?
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    the plug-in emissions tests just check for lack of DTC's, and I/M readiness - if you've recently pulled the battery, this'll be a few days. They won't care whether the up o2 sensor is a sensor or a resistor. Other emissions tests (visual or buttsniffer) are not so guaranteed.
    As for fuel - get it tuned, yes. But also answer this - does the fuel level drop noticeably if the car is just parked for a few days?
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Jul 2010
    Hookedonphonex
    it passed emissions. i filled the car up and am keeping track of the milage i will post up what i get when i need to get gas again.
    i have only been driving the car for a couple weeks now but it did sit for about a month while rebuilding the engine. it seems to be doing alot better. i do need to get it tuned im just not sure where to go or who to speak to since im new to the whole scene. not even sure how much its going to cost.?
    Registered User Fritz_the_Chick's Avatar
    Aug 2010
    Detroit
    $595 flat for OEM tune with Cobb AccessPORT. It's a flash tune, essentially, so I think anyone can do it. Mine is on the way; I'll post when I do it.
    Fast and Wrong.
    ~Blobeye Syndicate Member #2442~
    Jul 2010
    Hookedonphonex
    that is what i was looking at was cobb. just have not heard that much feed back. let me know how it turns out !!
    i heard getting it tuned by a shop can get you more hp than cobb anyone have any say on this?
    May 2007
    orlando flawduh
    Quote Originally Posted by wvh187 View Post
    a custom tune will definitely yield more power/better results. the cobb maps are very generic & conservative.
    i've had my AP for a while. it's very user friendly & gets the job done, but there are better options.
    desiree
    Feb 2010
    There's extra benefit in getting a protune - your tuner will be able to spot major engine problems before he starts - so he'll likely fix your fuel problem seperately
    Feb 2010
    SL,UT
    The poor mileage could be bad gas or a lack of reading from the o2 sensor... you can get it tuned via tactrix and laptop... there are many open scource stage 2 maps out there...
    Hawk-Eye Alliance #801
    Aug 2010
    Detroit
    Well, I'm getting the flash done to the ECU that is the 'basic'. The feedback (as I understand it) is: Cobb does what it is supposed to do--gives you about 10-15 more hp than stock, I think it gets rid of the speed limiter, and is a must-have if you do anything with your exhaust. So: do the Cobb flash with the exhaust. There's a sticky on this; essentially, the tune throws off the MAF and ECU. The more airflow there is screws up the OEM ECU because it was not designed to handle that kind of power. Remember: when you do the aftermarket exhaust and basic tune at the same time, you're gonna get about 30hp at the engine.
    After you do a flash tune with the Cobb (and that's what I understand is the standard for Sooby tuning), you can get your car dyno-ed at a qualified shop. This allows an expert to 'fine' tune the tune--making it specific to your car, calibrating adjustments and giving about another 10-15 hp.
    There are additional maps available from Cobb that can be downloaded to the flash tune. These, however, are customized for stage 3 (and beyond!). So...bigger turbo, beefier suspension...mega bucks...you'll pretty much be owned by a dyno place at that point.
    Fast and Wrong.
    Da boonies,Va
    If the OP is seeing 10 mpg's then no tune is going to magicly fix his issue. Its either a mechanical problem or his driving style................
    2002 FORESTER S
    1998 FORESTER S
