replacing all rubbers/bushings in sway bar
Results 1 to 9 of 9
This is a discussion on replacing all rubbers/bushings in sway bar within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so as i was changing the oil filter today on my car, i noticed the bushings at both ends of ...
    Aug 2010
    so as i was changing the oil filter today on my car, i noticed the bushings at both ends of the sway bar look VERY worn, so im thinking of replacing all the rubbers and bushings in the front and rear sway bars.
    is there any easy way i can get them all in one go? maybe some sort of kit?
    Registered User wrxmuch?'s Avatar
    May 2008
    Nashville
    energy suspension makes some replacement bushings.
    Cobb Accessport v1 stage 2 93 map, Nitto Invo Tires, Sti Front and Perrin Rear Sways, Rota Torque Wheels, APS Exhaust 3.5" turbo back. Catless TurboXS Up pipe, Goodridge Stainless Steel Brake lines, Hawk HPS Brake Pads, Paranoid Fabrications Cowl Braces, Group-N Tophats, Group-N Trans and Engine Mount, Tokico Dspec w/ Rce Black springs
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    going to need more info about your car to be able to accurately help.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2010
    its a 98 wrx. and they are selby sway bars.
    Moderator Donkey's Avatar
    Da boonies,Va
    If the bar is bigger than stock then you will have to get the appropriate size according to the bar size. Prothane, Super Pro and Whiteline all make aftermaket bushings in different sizes.
    2002 FORESTER S
    1998 FORESTER S
    Oct 2009
    Whiteline used to be selby. So they should have the sway bar bushings that you need. As for getting the others as a package.. if it were me, and I was looking to do them all I'd see if I could find all the group N bushings and replace all the factory worn ones with those. Should tighten things up nicely.
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2010
    whats the diameter of the stock sway bar do you know?
    and where can i get some more info on these "group N bushings"?
    Cheers.
    edit: i checked out those bushings, are they worth the price for a full kit?
    Sep 2010
    Guildford, Surrey, UK
    Hi,
    I've just received a kit of poly bushes for my WRX from these guys - http://www.strong-flex.eu/index.php, Took 10 days from poland to UK, All seem good quality and will be fitting them over the next few days. Quite cheap too, the kit I made up cost £158 delivered, same kit over here would be £350 odd...
    Hope that helps!
    John
    Aug 2010
    Quote Originally Posted by Bagpuss View Post
    Hi,
    Hope that helps!
    John
    cheers mate! this is what i was after.
    since posting this ive replaced sway bar links, and the "D" bushs in the sway bar, now ill move on to the rest of the suspension.
