brake light shows up on cluster?
Results 1 to 5 of 5
This is a discussion on brake light shows up on cluster? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just started the car this morning found out that my brake light stays on when I pulled the ebrake handle. ...
    Aug 2010
    stockton ca
    Just started the car this morning found out that my brake light stays on when I pulled the ebrake handle. Hmmm. Im just gonna take a guess I think it maybe my rear disc brakes is going out. Plz. Poet me up if I'm wrong.. what to do?
    Nov 2009
    Check the brake fluid reservoirs level. Make sure it is not low. If that is good maybe the e-brakes switch is not working properly.
    Aug 2010
    stockton ca
    Yea dude I checked the fluids it show that its rite above the line of min (barely ) but check been searching around its said I probably need to replace my rears pads.
    Registered User d_Ziggy_2000's Avatar
    Jun 2010
    Seattle(ish)
    I agree with the brake fluid check... but if neither of those work... try the tension on the break cable to see if it is fully releasing
    '88 Sub Justy *Rock in oil pan killed on freeway
    '87 Honda Civic *Bad pistons (to lazy to fix)
    '85 Nissan 200sx *Blown engine drifting
    '00 Sub Outback *Mother literally stole
    '92 Toyota Tercel *Hated it
    '02 WRX '07 kawasaki ninja. * current
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by evo-killer209 View Post
    And that would probably be why the light is on. There is a level sensor in the master cylinder. Generally if the fuid is low the calipers have expanded out so far because your pads are getting thin. You need to check both the front and read pad thickness. If they are with in spec then check for leaks. If no leaks then just top off the fluid.
    2002 FORESTER S
    1998 FORESTER S
