Results 1 to 14 of 14
This is a discussion on Help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; MY CEL IS ON. Im no mechanic and leave this to my brother but he's out of town so I ...
    Registered User vinesh's Avatar
    Aug 2010
    phoenix
    Help
    MY CEL IS ON. Im no mechanic and leave this to my brother but he's out of town so I need some help I think the previous owner of my car had straight pips installed and removed the catalytic converter or something is it suppose to show the cel? the car still runs like its suppose to has all the oil changes and necessary oils.
    Jan 2005
    Eh, whaaaaa?
    If the cat has been removed and no CEL fix has been done or the CEL hsn't been disabled with a tuning device, then yes, you'll get a CEL. To be sure, you should go to your local autoparts place (Checker/O'Reillys, or Autozone, unless you're in CA), and they will pull the code for free for you.
    Post up what the code is and we can help you from there, but with no code, we can't possibly know what the problem is. However, it likely is the code for the cat effeciency (P0420).
    Cody
    Aug 2010
    phoenix
    ya the code is P0420 from the autozone receipt I got back. Is it something that will kill my car or something I need to worry about. and is it the catalytic converter removal thing?
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by vinesh View Post
    Won't kill your car, no, it's just saying that the cat isn't doing it's job. It's not easy for the cat to do it's job if it's not there is it?
    Anyways, you can purchase mechanical fixes for this, it's basically a little spacer that goes between the bung on the downpipe and the sensor itself. Pulls the sensor out of the exhaust flow just enough to make the ECU think there's a cat there. I'd suggest purchasing that, installing, resetting your ECU by pulling the negative cable off the battery for a bit, and then trying again. Should be fixed.
    Cody
    Aug 2010
    phoenix
    ok thanks alot takes alot of my mind. Can I just keep the check engine light on and it wont mess up anything?
    Jan 2005
    Eh, whaaaaa?
    Aside from being annoying as all hell while driving? No, no issues, though I'd do the mechanical fix as soon as possible just to get rid of it.
    Here's a thread detailing how to make one for yourself:
    http://forums.nasioc.com/forums/show...6&pp=25&page=3
    Pretty cheap and easy as long as you have a 1/2" drill bit.
    Cody
    Aug 2010
    phoenix
    oooooooooooooooooo thanks alot
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    If you leave the CEL on, you won't know if something else is wrong though! So fix it fast!
    You can buy the spacers for super cheap off the intrawebz
    Aug 2010
    phoenix
    so there just called spacers or its called something else? sorry if im asking dumb questions.
    Nov 2006
    Denver Metro Area
    http://cgi.ebay.com/ebaymotors/Helix...Q5fAccessories
    Nov 2006
    Denver Metro Area
    with that exhaust you should get a tune...
    Aug 2010
    phoenix
    o ok cool thanks alot guys.
    Nov 2006
    Denver Metro Area
    yup! ps... remove your address from your profile...
    Oct 2010
    sorry to bring up an old thread but thought its better than starting a new one. I am getting a CEL with a cat code. My question is how do I know if its the cat in the downpipe or the pre-cat in the uppipe?
