Evap Emissions issue
Results 1 to 6 of 6
This is a discussion on Evap Emissions issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 02 wrx wagon, all stock besides cob 1 just hit 100k I am getting a P0456 code, ...
    May 2010
    NY
    Question Evap Emissions issue
    just hit 100k
    I am getting a P0456 code, Evaporative Emission Control System Leak Detected (small)
    and occasionally
    P0457 Evaporative Emission Control System Leak Detected (Fuel Cap loose or off)
    at first i figured bad fuel cap, so i just picked one up from autozone which didn't work
    so i picked one up from subaru, also didn't work
    i have been under the car and looked at the solenoid wiring and filler neck, and as far as i can tell it all looks good.
    i also had the dealer run a smoke test with no results.
    however this just caught my eye
    the lass few times filling up, i found the inside of my fuel cap and filler neck are soaked in gasoline as well as the rubber seal.
    and by the inside i mean from the seal to the threads
    and yes i always tighten the gas cap very well
    i dont really know much about the fuel system, but i dont think that there should be pressure forcing gasoline to and even through a well sealed gas cap.
    so i am stuck on this one, please help
    Registered User Spencer3636's Avatar
    Apr 2009
    No-Town
    ohhh boy, that is basically the same issue I have, still no resolution, once it gets real hot outside (95+) I start smelling fuel but the evap codes will go off whenever they feel the need.
    I have replaced the gasket on my fuel pump lid as well as the sensor lid on the opposite side, replaced fuel cap, pulled cleaned inspected all evap hoses under the passenger rear, checked filler neck, replaced charcoal box, smoke tested..... nothing, next week I will be replacing the solenoid after that I'm just going to get a bunch of fuel line and replace everything. Fort the last 2 summers i have spent entirely too much time trying to figure out this issue.
    It never did me any good to bring it to a shop either since they could never smell the fuel while it was there, and smoke test came up empty.
    Best of luck to you, i'll let you know if I figure anything out.
    Fuel smell from trunk.
    Carpe Diem!
    My 03 Bugeye is cooler than your mom
    Bugeye Mafia #222
    May 2010
    NY
    thanks for the post, let me know how it goes.
    also i think i posted the wrong code numbers before, however the descriptions i typed were correct, i will post back tomorrow with the correct code numbers
    May 2010
    NY
    p0442 not p0456 sry
    May 2010
    NY
    Question help please
    If anyone has some input please let me know
    I am still getting the p0442 and sometimes p0457
    Like i said before my fuel cap is getting fuel on it, so i really feel this is a venting issue and not actually an emissions leak somewhere. I believe the code is getting thrown because fuel is escaping from the gas cap, even when tight.
    If anyone has any know how on the venting system and where i should start, please let me know.
    May 2010
    NY
    replaced the vent control valve and rewired the clip.
    has been about a week with no code, im thinking its fixed
    easy part to replace, one bolt holding it on(assuming your bolt wont be as rusted as mine)
    and hoses are held in place with only friction
