2002 wrx misfire! PLEASE HELP! PLEASe!!!
Results 1 to 12 of 12
This is a discussion on 2002 wrx misfire! PLEASE HELP! PLEASe!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I have a really bad misfire in my 2002 subaru wrx. I have had the car for about a ...
    Apr 2010
    Lancaster, PA
    Hello,
    I have had the car for about a year now.
    it has 91000 miles on it.
    Mods:
    HKS turbo back exhaust
    Turbo Xs FMIC
    HKS type s bov
    turbo xs short ram intake
    COBB accessport V2
    Ok so here is my story,
    I got this car stock from a dealership with 80,000.
    I started to add modifications to the car. I got a 20G turbo with a 800cc injectors setup, high flow up pipe, and a COBB pro tune from alige automotive in maryland. Took the car home for the first day after everything was completed. I was breaking the car in, running around 17-18 PSI. Everything seemed to me working fine. Steady boost, Clean acceleration, no problems whatsoever. After about an hour of me toying with the new setup, the car starts to misfire, BADLY. So i decided to turn the boost down to a safe 10psi. The car ran great, normally. But now when i take the boost over 10 psi it misfires and stutters BADLY! The check engine light blinks, and throws 4 codes. 1,2,3 and 4 cylinders misfire code. I can take the car back under 10 PSI and it will run perfectly, even at redline. I took it to the dealership and they had no idea. They said they couldn't help me because of all the modifications i had done. I checked everything, to spark plugs, vacuum leaks, MAF, the pro tune, i even changed the MAF and cleaned out my inter cooler & piping. Changed spark plugs, Checked the spark plug gaps. I DID EVERYTHING I COULD POSSIBLY THINK OF! I tried running 103 octane. Still nothing. I'm going crazy.
    OK so here is the funny part.
    I'm pretty good with automotive mechanics & turboed cars,
    So i decided to take everything off and change it back to stock. Since i still had all of the stock parts and could do all the labor myself. So i put the TDO-4 stock wrx turbo back on, and the stock 465cc blue injectors, and the stock cobb accessport map. AND THE CAR DOES THE SAME THING! It will run perfectly under 10 PSI but when i take it over 10, It misfires and stutters BADLY.. Im ready to give the car back, i cant take it.
    IF ANYONE CAN THINK OF ANYTHING! PLEASE REPLY TO THIS POST!
    IM BEGGING YOU GUYS FOR HELP!
    please!
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by subbyrex View Post
    Hello,
    Mods:
    Turbo Xs FMIC
    HKS type s bov
    COBB accessport V2
    please!
    So when you FIRST bought the car with all the stock parts did it do this?
    Apr 2010
    Lancaster, PA
    No it ran perfectly. Like a regular stock 2002 wrx would.
    I test drove a couple a this one seemed to be the best.
    It was set at 15 PSI when i got it from the dealership.
    Ran perfect at that boost level for 3 months before i made the upgrades.
    I'm stumped and will read on to hopefully learn something. Are you sure the map used with the stock parts was a stock map? Do you have any data from the time the misfire events occur? If so, post them and see if anyone can sort it.
    Apr 2010
    Lancaster, PA
    I have tried using COBBs stage 2 map and it does the same thing. I'm not too familiar with data logging? are you referring to data logging with the accessport? and could i get basic instructions on how to data log and what data would be most helpful?
    thanks
    Feb 2010
    Fort Worth, Tx
    Hello,
    Mods:
    Turbo Xs FMIC
    HKS type s bov
    COBB accessport V2
    please!
    Do yourself a favor and take the ram air intake the bov off and just run the stage 2 base map it should run better.
    Apr 2010
    Lancaster, PA
    Quote Originally Posted by Tegy View Post
    tried using the stock intake and intercooler. and bpv
    Registered User Skreekin's Avatar
    May 2005
    Bellingham, WA
    Bring it back to your tuner. See if they can data log and see where the issue is.
    2005 WRB WRX Stage 2
    Blobeye Syndicate #76
    A Must Read http://www.clubwrx.net/forums/engine...do-not-do.html
    Registered User Graham46's Avatar
    Mar 2010
    Harford County, MD
    +1, why would you take it back to the dealer instead of Agile? Im sure they will have a better idea of whats going on
    2006 WRB WRX Sedan @ Stage 2
    www.grahamsnodgrass.com
    Nov 2009
    Get a compression test to make sure the engine is still healthy.
    Aug 2008
    Quote Originally Posted by oguitar View Post
    +1 ^..my thought exactly...if it ran great from the get go than after the mods where installed it ran like crap....hmmm....
    Jan 2005
    Eh, whaaaaa?
    I don't see a fuel pump on that list. I'd be highly suspect of it if you had it tuned on the stock pump, which is just foolish to start with.
    Get the compression test done and do a fuel pressure test as well to make sure your pump is working correctly.
    Cody
