check engine light
Results 1 to 2 of 2
This is a discussion on check engine light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have an 04 wrx with the check engine light on. i had 4 shops hook up an obdm reader ...
    Aug 2010
    ny
    check engine light
    i have an 04 wrx with the check engine light on. i had 4 shops hook up an obdm reader it wont let the reader get as far as seeing the code.it just reads check fuse box and ground, so obviously we used a fuse tester, tested all the fuses n ground.theyre fine. check engine lights on and i think this is being caused by a bad harness by some miracle the car is starting ..any thoughts or ideas?
    Aug 2008
    Kennett Square, Pennsylvania
    In the years and years I have been working on Subarus I have NEVER seen this happen, Did you take it to the dealer? What did they say? First make sure the green PDI connectors aren't plugged in. Do you notice any drive ability problems? How many miles are on the vehicle? Have you had any recent work done?
